Click Here
78 delta 88
Old Feb 26, 2021 | 03:08 PM
J1978's Avatar
78 delta 88
Wondering if anyone knows what bolt pattern I should go w/. Looking to get rally rims.
wanting to put new wheels/ tires on my 88.
any help thanks
1978 delta 88
Old Feb 26, 2021 | 06:59 PM
rocketraider's Avatar
Oldsdruid
If it's a 350 car without HD suspension it has a 4-3/4" bolt circle and wheels from a Cutlass or other GM A-body or God forbid Chevy Rally will fit.
If it's a factory 403 car, or 350 with HD suspension it has a 5" bolt circle. Not many factory 5x5 sporty wheels available. Buicks and GM trucks had them, and Olds offered SSIV Polycast and N82 Chrome Wheel Option in the 70s.
Old Feb 26, 2021 | 08:36 PM
J1978's Avatar
@rocketraider It’s originaly a diesel 5.7L I got it swapped for a Chevy 5.7L 350 SB
Old Feb 26, 2021 | 09:20 PM
Oldsdruid
I can't swear to Diesel cars but I think they had 5x5. Joe Padavano will know for sure.
Old Feb 27, 2021 | 04:54 AM
J1978's Avatar
Ok thanks for the help anyways.
I am also wanting to install a new dual exhaust system and put 2 flow master super 10. Muffler
i basically am wanting a sporty look/sound
think about putting some rally rims on her.
Old Feb 27, 2021 | 07:07 AM
The easy way to tell is to look at the brakes. The regular-duty cars came with 10.75" front rotors and 9.5" rear drums. These have the 5 x 4.75" bolt pattern. The HD cars came with 12" front rotors and 11" rear drums and used the 5 x 5" bolt pattern.
Old Feb 27, 2021 | 09:40 AM
J1978's Avatar
Oh ok. Would you happen to know if I can possibly put 17” wheels on it?
and if so would I have to do any configurations involving the rotors or pads?
Old Feb 27, 2021 | 09:43 AM
The stock wheels were 15". Obviously anything larger will fit, assuming you get the correct bolt pattern, width, and offset. As for clearance, tire width and outside diameter also matter.
Old Feb 27, 2021 | 06:32 PM
J1978's Avatar
Ah ok any chance would you know about the manifolds sizes and specs? I’m gonna need a new exhaust system as well. And thank you all for the help!
Old Mar 16, 2021 | 01:19 PM
llevine's Avatar
where can i find window trim for this car and interior parts
Aussie67Delta88Custom
Brakes/Hydraulic Systems
Apr 20, 2020 05:14 AM
Dboi78
Cars Wanted
Jan 25, 2018 11:49 AM
ddd777
Aug 5, 2015 05:12 PM
