Click Here
67 offset..
Old Jul 30, 2010 | 06:22 AM
Ranzan's Avatar
Getting There
67 offset..
I`m almost at the stage of getting Rims.. fingers crossed..
I`m going to go with the new chromed aluminum Crager SS rims with spinners for the classic look... does anyone happen to know the backspacing I can get away with since my body is still off the frame?
Old Jul 30, 2010 | 07:09 AM
ddx77's Avatar
I can check what mine are for you later if it will help, although I am not sure if my backspacing is the max or not.
Old Jul 30, 2010 | 07:48 AM
Oldsmaniac's Avatar
I am pretty sure a 5 inch backspace on a 8 inch wheel will work. I had corvette wheels on my 67 conv which I believe are 4 inch spacing on an 8 inch rim and I had a little room to spare on the back side..... It is best to measure as you would not want to order wheels that wont work.
65 Delta Guy
Dec 25, 2011 09:37 AM
STLCRZY
Suspension & Handling
Aug 18, 2011 12:48 PM
Mark71
Aug 1, 2011 03:03 AM
my72vert
Jan 1, 2011 07:36 PM
1973olds98
Wheels and Tires
Jan 31, 2010 10:22 AM
