Click Here
295 tire fitment on lowered car
Old Aug 22, 2016 | 08:04 PM
DewChugr's Avatar
Photoshop God
Will 295 tires fit on a lowered 71? If so how much can it be lowered and have them fit well? Is 295 about the limit on a 71?
Old Aug 22, 2016 | 08:09 PM
Qwik71442's Avatar
Full-time Taxpayer
295's will fit. I have a set of 325's on a 71 that fit with no problems.
Old Aug 22, 2016 | 08:14 PM
DewChugr's Avatar
Photoshop God
Wow, that's a wide tire.
Old Aug 22, 2016 | 08:46 PM
Make sure you have the correct wheel backspacing for the tires to clear everything.
Old Aug 23, 2016 | 07:39 AM
DewChugr's Avatar
Photoshop God
Is this car lowered and what size tires are on it?
Old Aug 23, 2016 | 08:13 AM
Qwik71442's Avatar
Full-time Taxpayer
215/70/15 on 15x6 Front Lowered 2.5"
325/50/15 on 15x10 5.5BS Rear Lowered 2"
Old Aug 23, 2016 | 08:17 AM
DewChugr's Avatar
Photoshop God
I need 17 or 18 inch wheels, but that looks awesome.
Old Aug 23, 2016 | 09:09 AM
oldsmobiledave's Avatar
Curious
Why do you NEED 17-18? Brake upgrades?
Old Aug 23, 2016 | 10:17 AM
DewChugr's Avatar
Photoshop God
Yes, C6 brakes.
Old Aug 24, 2016 | 03:16 PM
oldsmoboogie's Avatar
What brand tire is that quick71?
Old Aug 24, 2016 | 06:07 PM
Qwik71442's Avatar
Full-time Taxpayer
Mickey Thompson
Old Aug 24, 2016 | 06:56 PM
Mr Nick's Avatar
285/40/18 on the back, lowered a good 2" or more. The fenders lips are rolled and I have no rubbing. I don't recall my exact backspacing, but I have a good .5" space between inside of tire and frame rail.
I'm told the 70-72 cars have more room in the back than 68/69. You should be able to get a 295 back there no sweat.
Old Aug 24, 2016 | 08:07 PM
70cutty's Avatar
Beer Connoisseur
305/40/18 on 18x10 with 5.75 backspacing. BMR 2" drop springs rear. Fits with room to spare.
Old Aug 25, 2016 | 01:05 PM
71 OLDS's Avatar
Nitto 305 45 18 drag radials on 18 x 10's. BS is 6 because the 12" Baer rotors in the back push the tire out about .5". If you run stock drums or even smaller rotors in the back it would probably still be 5.5 BS on a 10 rim. Make sure you get that right or you will rub for sure. If you are going to add bigger brakes later - wait to order your rims or be prepared to have to get new ones AFTER you upgrade the brakes. Same goes for the fronts. Rear has CPP 2" drop spings. Had to roll fender well lips, massage inner wells with a BFH, and put dents in both 3" tail pipes where the tires get close but....I get sideways a lot and do some hard cornering. If you're doing mostly straights and not getting sideways or taking really hard corners you could probably get away with less clearance than me..
BFG white letters are glued on just for the look but these are Nittos.
Old Aug 25, 2016 | 01:30 PM
DewChugr's Avatar
Photoshop God
Thanks for the info. I have C6 brakes I am going to be putting on so I know I need at least 17" wheels and they are fairly big calipers.
MyFathersOldsmobile
Apr 3, 2016 09:13 AM
oldzzy
Wheels and Tires
15
Dec 15, 2013 11:03 PM
yankees
Wheels and Tires
Mar 24, 2012 02:47 PM
Rolds72
Wheels and Tires
Mar 13, 2012 03:26 PM
#1CutlassSupreme
Jan 4, 2009 06:02 PM
