17 to 18in is it worth the extra 1000 bucks
I'm going through this problem now, i really find these posting helpful. Right now I have a set of American Racing Torque Thrust II's 17in. I have a 71 cutlass 442. The car is being rebuilt after an engine fire which happened before I bought it. But i need to make a decision about wheels and tires. Do i keep the wheels that are on it now and save 800-1000 bucks and just get new tires, or do i replace rims and tires at the same time and step up to an 18in wheel......... Anyone have any thoughts??????????? (rims are in perfect shape just need cleaned and polished) Been looking at some coy c-5 rims?????
My own opinion but just buy the new skins for them and let them roll you never know if that 800 TO 1000 might be needed for more Hidden things that fires can create and the seller nor you are aware of
yeah, I agree and I also feel that although there are plenty of rims that look good in 18 and over these cars are fine with 14 - 17 inch rims. If I ever get a set of custom rims I most likely will stick with 16 or 17s keep the money for something else
thanks for the advice, Cars like this are constantly costing money but by the time i'm done i will have went through the entire front end of the car. So their won't be much of anything that could break. However I do think i will just replace the tires and leave the rims. Good suggestions thanks
I'm not a big fan of "rubber band" tires. The 1960s and 70s cars look best with the wheelwells filled. That usually means a TIRE diameter (not wheel diameter) of 27-28 inches. Most tires for large diameter wheels max out around 26 inches, but there are some exceptions. I also don't think lowering the car to close the daylight gap above these smaller diameter tires looks that good, as the arc of the wheel opening does not match the arc of the tire. Of course, there's the other problem that the shorter sidewalls lead to bent rims when these tires and wheels are driven in the real world...
Got a photo of it with the 17s on? I personally like the Torque Thrust wheels on just about any 60s & 70s muscle car or classic. 17x7 up front & 17x8 on back. I'd stick with them and put your money away for necessary stuff.....like women and alcohol.
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
I'm not a big fan of "rubber band" tires. The 1960s and 70s cars look best with the wheelwells filled. That usually means a TIRE diameter (not wheel diameter) of 27-28 inches. Of course, there's the other problem that the shorter sidewalls lead to bent rims when these tires and wheels are driven in the real world...
Ever try riding a bicycle with a flat front tire? That's an exaggerated version of what happens to the 28" tall 185/15 stockers. I'll sacrifice the handling for the classic looks because my cars pretty much just need to go straight.
Some other people enjoy trying to bob n' weave with these old tanks I guess.
I'll be putting exactly the same wheels on my 72 when it arrives.
the new ones im going with are going to be 245/45 zr17 in front , and 265/45/zr17 in rear but the ones in the picture are a 245, i'm going to keep the same size in the front and get a little larger tread pattern in the rear. I think bfg g-force. Those tires in the picture have lots of tread left but are all dry rotted. The car is very low miles and like i said tire tread is like new only tires are cracked all over.
On my 72 442, I have TTII's 17x8's w/245-45's front and 17x11's w/315-35's on the rear and I love the look and just about everyone else seems to like the look as well! I have had these wheels and tires since the 90's but I still think they look good and are not "dated".
well i already have the rims on the car or i would go with a larger tire in the rear but I'm pretty sure without looking yet that the rims are a 17x8 or at the most 17x9's so I think the max i can probably go with is a 265. A 305 is enormous!! wow you have any pictures ????
Unless you have a specific disc brake upgrade in mind that REQUIRES an 18" wheel, it's a waste of money.
J-(Chicago)
Drivetrain/Differentials
December 11th, 2007 07:08 PM
