Click Here
15x8 back space?
Old March 10th, 2016, 05:43 PM
dgp1042's Avatar
15x8 back space?
Ordering new SS1 rims from Summit for a 71 442 with stock suspension. Not sure what back space to order for the rear wheels. Putting 15x7 on front with 4.375 BS. 15x8 on the rear... they offer 4.5 or 5.0 BS for the 15X8's. The tires are Goodrich TA's 235-60-15 front, 275-60-15 rear. What BS should I order?
dgp1042 is offline
Old March 10th, 2016, 05:46 PM
Full-time Taxpayer
Qwik71442's Avatar
Originally Posted by dgp1042
ordering new ss1 rims from summit for a 71 442 with stock suspension. Not sure what back space to order for the rear wheels. Putting 15x7 on front with 4.375 bs. 15x8 on the rear... They offer 4.5 or 5.0 bs for the 15x8's. The tires are goodrich ta's 235-60-15 front, 275-60-15 rear. What bs should i order?
4.5"
Qwik71442 is offline
Old March 10th, 2016, 06:17 PM
dgp1042's Avatar
Are you sure, Once I order these and mount tires no returning them. Will the 5.0 BS not leave enough rim on the outside and look funny compared to the front rims?
dgp1042 is offline
Old March 10th, 2016, 06:24 PM
Beer Connoisseur
70cutty's Avatar
4.5" BS is the way to go, or 4" if it's an option, that would give you more lip.
70cutty is offline
Old March 10th, 2016, 07:05 PM
Full-time Taxpayer
Qwik71442's Avatar
Both back spaces will fit in the rear but the 5" will not look right. The 4.5" backspace will look better in relation to the front. You could actually put the 15/8 with 4.5 BS on all 4 corners.
Old March 11th, 2016, 07:13 AM
oldsmobiledave's Avatar
Fyi
This is 275 60 15s with 4.5 BS on the back of my W machines.
In my opinion it is perfect.
oldsmobiledave is offline
Old March 11th, 2016, 08:13 AM
dgp1042's Avatar
Thanks guys! Yep 4.5 that's it then. I'llk order them today! Nice cars oldsmobiledave.
I'll post pictures when I get the tires/wheels mounted. Replacing the stock 14" SS11's. I'll keep the 14's for originality but I believe the ride and look of 15" SS1's will be better.
dgp1042 is offline
Old March 11th, 2016, 10:45 AM
more
Good decision & exactly the thought process that I went thru.
You may want to consider 245 60 15s up front rather than the 235 60 15. Or if you want a front tire closer to the same height do what I did on my cars & go with 225 70 15s up front.
yankees
Wheels and Tires
July 23rd, 2014 03:45 PM
87442
Wheels and Tires
June 17th, 2011 04:11 PM
y19cutlass
November 10th, 2010 05:45 PM
D Appeldorn
July 18th, 2010 07:27 PM
gearheads78
August 7th, 2009 04:00 PM
Quick Reply: 15x8 back space?
