14" SSII for disc brakes
Every single SSII or SSIII wheel ever made by Oldsmobile from 1968 (when they first came out) to 1988 (when the last were made) will clear the factory 10.75" disc brakes. If you have aftermarket brakes, it depends on how close they are to stock. If you have aftermarket SSII/III wheels in a non-factory size, no guarantees.
SSI wheels did come in drum-only and disc brake versions.
The trick is to look at the backside of the rims. I stole these sketches and photos from H.A.M.B. The sketch shows the difference in backside contour for the drum-only (left) and disc (right) wheels.
Now look at these photos. The first is a drum-only wheel.
This is a disc brake wheel. Note both the contour difference and the circumfrential groove. The groove is present on all factory disc brake wheels and is an easy identifier. I cannot say that this feature applies to aftermarket wheels, however.
W-27
October 5th, 2016 09:34 PM
DJS70cutlass
Brakes/Hydraulic Systems
June 9th, 2014 09:44 AM
MDchanic
Wheels and Tires
22
August 4th, 2011 11:23 AM
81 regency
April 21st, 2011 07:18 PM
