14 INCH SS1's Need Tires
Hello,
I bought the BFGoodrich Radial TAs on my 1972 442 in 1987, so even though they have some tread left on them, I think that I should replace them. I have 225/70/14 size on now, but was wondering if anyone was running 235/60/14 or 245/60/14. First need to know they fit without any modifications or rubbing. Second need to know how the look with a slightly smaller diameter/profile. Third is the tire width that I would be gaining work changing the profile apperance. And if anybody has any pictures of this size tire/wheel combo on a 70-72 Cutlass, I would love to see them. I have no interest in changing the wheel size to 15 inch.
KMP
72 442 Convertible
11 Genesis 4.6
11 Venza
KMP
72 442 Convertible
11 Genesis 4.6
11 Venza
Here's a shot of my car with 245-60-14 BFG Radial T/As on factory 14x7 wheels.
I should point out that I installed 442 FE2 equivalent springs which sit about 1" lower than regular Cutlass springs, so the tires fill the wheel openings fairly well. Since you have a 442 you should already have similar springs on your car.
The 245/60s are a full inch smaller in diameter than the 225/70s. The 235/60s are even smaller than that. I do think that the look too small, especially on the rear. There's a lot of daylight between the rubber and the wheel opening in the photo above.
The flip side is that 225-70s are way too skinny when viewed from the rear. 245s still leave a lot of fender well space, but it looks a lot better.
Wider tire/shorter sidewall helps handling.
The shorter tire also reduces the effective gear ratio, providing a slightly "lower gear" for enhanced performance without swapping the rear.
How they look is a matter of personal preference.
The skinny 225-70s going up in smoke off the line would prolly make a bigger difference than the tire height. Been there, done that.
Agreed.
Of course, not everyone cares about drag racing. The O.P. should collect all the data and make an informed decision based on his own driving and appearance preferences.
I currently use 245 60 14 BFG Radial TA installed on SS II rims. They look just fine and perform well on both the 70 Cutlass Supreme and the 70 Cutlass Supreme SX. Two sets of five on two cars and I have not looked back.
A lot of good information here, thank you. I value everyone's opinion on this subject. My drag racing days are over. But back in 89 or 90 I ran this car on the same 225/70/14's that are still on it at the Super Car Showdown (anybody remember those?) and ran 13.90's. Now I just want her to look good and handle well on the street and for cruises and shows. But I do still like to get on it and chirp second gear.
dz442
Sep 6, 2019 03:55 PM
Elephant_Engine_Ernie
Jun 1, 2011 07:59 PM
