How to remove a Custom Cruiserr tailgate
Old Nov 15, 2024 | 06:08 PM
The Stickman's Avatar
I need to replace the tailgate on my 1984 Custom Cruiser. I have heard removing these are hard because if the dual action opening and I think I remember hearing torsion rods. Is that correct? Either way How is this best handled.
Old Nov 16, 2024 | 05:05 AM
jaunty75's Avatar
I'd start by getting one of these. $20 on ebay.
Old Dec 6, 2024 | 04:26 PM
Fred Kiehl's Avatar
It should be about the same as my 91 OCC. There is a wire spring on the driver's side...open the gate as a door, and disconnect the spring. Disconnect the wiring and remove it from whichever end is easier. If there is a conduit between the gate and body remove that as well, Close the door and remove the nuts holding the driver's side hinges to the body. You can then open the gate as a door, and pull the hinge studs out of the body on the driver's side. You should have a very heavy tailgate in your hands. I suggest having a friend or two give you a little help with it. Install is the reverse.
Old Oct 29, 2025 | 07:56 AM
billybob20's Avatar
the car only has 87,xxx original miles and is in very good condition, no rust anywhere but if all else fails, I'l try to remove the door gate and really give it a good look over. thanks for the suggestion.
Oldsguy
May 31, 2023 03:11 AM
71Custom
Cars Wanted
May 2, 2022 06:47 AM
tommytron
Apr 7, 2016 08:48 AM
oldsmobilediesel
Cars Wanted
Jul 21, 2012 08:48 AM
Oldsmobile Girl
Oct 19, 2011 07:34 AM
