90 model custom cruiser
My 86 does that as well. It will shut off eventually if you keep turning them on and off. I was told it's probably the park switch, but I'm not sure. Could be the actual column switch too. Changing the motor out is probably the easiest. I found one at Autozone or Checker for about $50. The new column switch is pricier and a PITA to change out so I figured I'd start with the easiest and see if it works
You can't. The GM wiper motor uses a shunt winding. The high speed winding is conventional, but low speed uses a reverse wound shunt winding that is energized at the same time as the high speed winding. You need the factory switch.
Fred Kiehl
Jun 16, 2013 04:55 AM
