1964 Vista needs a new radiator
Old Nov 10, 2023 | 02:29 PM
mathon's Avatar
1964vistacruiserwagon
Any suggestion of best place to buy a radiator for a vista with 330. Its a 64 so the water pump inlet/outets are on the opposite sides as later 330's. Has auto trans. Prefer a stock looking unit. My original Harrison radiator has a bad core....
Old Nov 10, 2023 | 02:32 PM
Funkwagon455's Avatar
Find a reputable radiator shop to recore your original tanks. Not cheap, but not cheesy looking either.
Old Nov 10, 2023 | 03:17 PM
Sugar Bear's Avatar
^^^ X 2k!!! ^^^
Old Nov 10, 2023 | 03:43 PM
Originally Posted by sugar bear
^^^ x 2k!!! ^^^
sold!!
Old Nov 10, 2023 | 04:00 PM
I forgot to mention, your original copper core has substantial value. Once the repair price is established by the shop, be sure to indicate that you’d like to retain your original core. You can either recycle locally and use the money towards the repair or perhaps the shop might offer to compensate you it’s value as a discount on the repair.
Old Nov 10, 2023 | 04:58 PM
mathon's Avatar
Thanks for the advice. I guess no off the shelf replacements are easily available...
Old Nov 11, 2023 | 10:12 AM
Note that the upper inlet port is located differently for A/C and non-A/C.
https://usradiator.com/radiator-find...-85&_year=1964
Old Nov 11, 2023 | 12:15 PM
2blu442's Avatar
I've got a used 1964 radiator if your tanks aren't good. I'd still want to replace the core as it's an original unit. Another option I've heard of is to add the lower part of a 1965 core support to your 1964. Then you can either change the water pump to the newer style or have a radiator shop swap over the hose connection to the correct side. That would open more options for a replacement radiator and give you a larger radiator as well. John
Old Nov 13, 2023 | 11:33 AM
mathon's Avatar
Found a shop to recore the radiator for $800. Tanks are perfect. Many tubes are corroded and leaking. Core is bulging at the sides too.
Old Nov 13, 2023 | 11:46 AM
Before/after pics please.. The last one I had recored was about $600 over ten years ago, your price is likely typical for today. It’s getting harder to find radiator shops these days. The industry seems to be going disposable.
Old Nov 13, 2023 | 01:03 PM
Rallye469's Avatar
600? 800? Ouch.
6 months ago I paid $375
Old Nov 13, 2023 | 04:08 PM
600? 800? Ouch.
Is your radiator shop using copper cores? If they are, I’ll consider eating the shipping costs to send 2X to/fro the Sunshine State!!😁. $375 sounds super low.
Old Nov 13, 2023 | 08:09 PM
mathon's Avatar
The shop doing the work is ordering a core custom sized from a builder in detroit. They will send it to kansas city where the cleaned tanks will be soldered on. Yes its a new copper core. Old core is original and copper, but is bulged, has cut and dead ended tubes and is pretty clogged.....
Old Nov 13, 2023 | 08:21 PM
Sugar Bear's Avatar
Any ID tags on the old one worth keeping?
Old Nov 14, 2023 | 02:22 PM
mathon's Avatar
who did the $375 re-core? Was it a good job?
Old Nov 14, 2023 | 04:55 PM
Agreed, Mathon, If your current radiator has metal ID tags, be sure to let whoever repairs it to reinstall them!!
Old Nov 14, 2023 | 05:44 PM
mathon's Avatar
It has small numbers that seemed to be stamped on the edge of top tank, where it meets the core...
Old Nov 14, 2023 | 07:42 PM
Negative, we are referring to thin metal tags crimped to the solder area. Perhaps the year ‘64 didn’t have them
Old Nov 29, 2023 | 01:59 PM
mathon's Avatar
1964 olds vista radiator "tag"
Old Nov 29, 2023 | 02:02 PM
mathon's Avatar
1964 radiator tag "AC"
Old Nov 29, 2023 | 02:03 PM
Looks like "AG" from here.
Old Nov 29, 2023 | 02:05 PM
mathon's Avatar
New re-core radiator 4 row
Old Nov 29, 2023 | 02:17 PM
Looks good.. I’m sure that you will not regret going this direction. I’m surprised that the tanks look as crusty as they do though.. I’d probably mask off and chemstrip the tanks to clean metal and respray them sanitary..,,Or not. It would not affect the functionality. 😀
Old Nov 29, 2023 | 02:21 PM
mathon's Avatar
old 4 row core
Old Nov 30, 2023 | 08:56 AM
mathon's Avatar
your right, my eyes are bad!
lass4ken
Apr 8, 2022 02:03 PM
LARams1
Jul 10, 2021 09:43 AM
SanTan Devil
May 7, 2019 11:27 AM
tlenig
Apr 24, 2016 05:41 AM
trackz man
Mar 4, 2011 01:44 PM
