1957 98 - Engine stalls idling on a hill
Old Nov 10, 2014 | 02:59 AM
john116's Avatar
I have a problem with my 1957 Oldsmobile 98, which has stumped me. On steep hills, or on emergency stops (when the car lurches forward/downwards) the engine just stops running. Testing it on a steep hill, driving up the hill, if I take my foot off the accelerator, the engine dies. I can restart it again straight away, but it will stop if I don't hold down the accelerator.
On the flat, it idles perfectly. My car has the J2 option, which does work although obviously at idle speeds it won't be doing anything.
The car has an automatic transmission. Apart from this problem, it seems to drive normally, although one other thing I've noticed is that it's often hard to start, requiring much cranking. This happens whether it's been left for a day, or just a few minutes after being used.
I've checked the float level, fuel tank pick up (although as it dies so suddenly I didn't think it would be fuel tank related).
Any thoughts? I'm stumped!
Old Nov 10, 2014 | 05:27 AM
What is your dwell, timing, and idle speed set to?
Old Nov 10, 2014 | 10:03 PM
john116's Avatar
Timing and idle set as per service manual, no dwell, electronic ignition installed.
Not sure that would make any difference though whether it's on flat ground or a hill.
Old Nov 11, 2014 | 06:08 AM
Check your fuel line before the fuel pump as they get soft, crack and suck air. Make sure your timing advance is working properly? Make sure the throttle is set correctly, and the butterflies on the unused carbs at idle are closed.
Old Nov 16, 2014 | 01:01 PM
pete324rocket's Avatar
Check the fuel float level in the carb. I know that hard right or left turns and stalling is because of improper float level, a hill may be similar.
Old Nov 16, 2014 | 07:27 PM
Tedd Thompson's Avatar
Hard start is very common with today's gas with these era cars.Often my car will need 10 or 12 cranks to get things going after a three day rest. I don't have a idea on the stall on a hill unless somehow your gas pickup is sucking air in that position...Just a guess...Tedd
Old Nov 17, 2014 | 10:41 AM
Ozzie's Avatar
It sounds like fuel/air related. As has been said, be sure that the end carburetors are closing completely and that the fuel pump to chassis hose is not sucking air due to cracks. Probably a fuel pump check for pressure and capacity is in order. The manual says that the pressure should be 4 - 5.25 pounds. I once had one that was sucking air around the perimeter of the fuel diaphragm and wouldn't move the fuel after sitting for a while. If yours has the glass bowl on the pump, be sure that there is no leak or congestion there. Also look for any congested fuel filter elsewhere. If all that checks O.K., then you may have to go inside the center carburetor and look closely at the float & needle/seat.
Octania
Jul 10, 2015 09:21 AM
joesw31
Feb 15, 2015 01:22 PM
oldsonharmont
May 28, 2011 07:09 AM
Prsabordo
Feb 9, 2010 09:58 AM
<sparkmn13>
Dec 15, 2006 05:51 PM
