1937 Fuel Pump ?
Old Feb 28, 2012 | 05:36 PM
deaddds's Avatar
1937 Fuel Pump ?
My 37 is the inline 6. I have an electric pump on it that works fine and I have a mechanical rebuilt pump that I wanted to put on. Question is should I put a switch inline to use the electric as a primer or emergency pump or can I put the mechanical on and would it be able to operate the vacuum wipers without a direct fuel line? As you can guess I currently do not have wipers, that's how I figured out the mechanical pump on the car was not hooked up, it was bypassed. I didn't know if the vacuum for the wipers is created from the liquid fuel or just the action of the pump arm or if I will roach the pump without fuel to cool it? Any advice would be great.
Old Feb 28, 2012 | 06:26 PM
Tedd Thompson's Avatar
I'm not sure about a 37 but on later models the vacuum is created by a diaphragm on top of the fuel pump and should not have any effect on fuel delivery. It's there for the wiper motor only.
As far as needing a source for a primer if it didn't have one when new it shouldn't need one now....Tedd
Old Feb 29, 2012 | 06:32 PM
Funkwagon455's Avatar
[QUOTE=Tedd Thompson
As far as needing a source for a primer if it didn't have one when new it shouldn't need one now....Tedd[/QUOTE]
True.......but then again the electric primer does not hurt. A discreet installation can be barely noticeable, and can make for faster fuel delivery on an already lethargic 6 volt start. (ie: less cranking/low speed oil circulation) Use judgement that best suites your driving tendencies.
Old Mar 1, 2012 | 03:22 AM
Yellowstatue's Avatar
And you could run the output of the electric pump through the mechanical pump and pretend it is cooling it...and on to the carb.
deaddds
Mar 20, 2012 06:55 PM
crzyjef
Nov 30, 2010 11:47 AM
Kferen
Jan 30, 2010 07:24 AM
lshlsh2
Jan 29, 2010 06:54 PM
Kferen
Oct 24, 2008 06:49 PM
