Radiator 1956
Old Aug 24, 2011 | 05:57 PM
Joey Lights's Avatar
Radiator 1956
Hello everyone.
I am looking for a radiator for a 1956 Olds 98. It has the 5.3. Anyone have a place they recommend?
Old Aug 24, 2011 | 08:36 PM
Tedd Thompson's Avatar
radiator repair
Check with your local radiator shop they will probably be able to repair your old one cheaper than buying a new one.
You use a interesting term for a 324 engine(5.3). Are you living outside of the states? If so a new radiator can be had from USA Parts(703)335 1935 part#s1219r.It will be expensive though....Tedd
Old Aug 24, 2011 | 08:40 PM
AZ455's Avatar
1974 DELTA 88
I like Radiator Barn. They don't have inventory past 1960 listed on their website, but they may be able to help you anyway. You can fill out this form and they'll get back to you. I've had good luck with them in the past, good quality radiators, they even sent me a free hat once...
Here is the form to see if they have a rad for your '56. Good luck.
https://www.radiatorbarn.com/help.php
Old Aug 24, 2011 | 08:41 PM
Ted,
I use the term 5.3 because of my mechanic experience with some other cars. I will start to use the 324. I live in Atlanta, GA area.
I will check out USA parts. I know I need a new one. Lots of holes in it. Do you know is USA parts is going to be quality? there price is up there, but worth it is if it good quality.
Joe
Old Aug 24, 2011 | 09:09 PM
I have had good luck using USA parts in the past.I have never bought a radiator so I don't know about quality,I did purchase a heater core and have had no problems.They have never been cheep so shop around.
Even If your radiator leaks it could be re-cored(old top and bottom new middle core). This is a common repair on older radiators and is cheaper than a new radiator....Tedd
Old Aug 26, 2011 | 08:25 PM
56oldssuper88's Avatar
youngin'
Hemmings motor new has some radiator places listed in there.
Old Aug 29, 2011 | 07:06 PM
I took it to a radiator shop in town to get it recored. That's the way to go! Thank for the help everyone.
Alex72cutty
Apr 21, 2015 10:30 AM
59Olds98
Aug 14, 2013 09:38 AM
<chris kumerow>
Sep 30, 2012 06:17 AM
g77rvd
May 13, 2011 11:29 AM
<David>
Jul 13, 2004 05:45 PM
