Hydra Matic Fluid
Old Jun 19, 2022 | 10:05 AM
57J2Olds's Avatar
Hydra Matic Fluid
Hello,
Can anyone please tell me what type of auto trans fluid would work in my 1948 Olds?
Old Jun 19, 2022 | 11:31 AM
Tedd Thompson's Avatar
Any of the Dextron's will work fine, they are all compatible in your car and can be intermixed with what ever number they are on now.... Tedd
Old Jun 19, 2022 | 11:34 AM
rocketraider's Avatar
Oldsdruid
Original was Type A Suffix A. Made with whale oil and long out of production.
If you can find Dexron III / Mercon III that will be the best modern equivalent. V, VI and however many Roman numerals later will probably be OK but they're formulated for different conditions and materials than III.
Old Jun 19, 2022 | 01:34 PM
Charlie Jones's Avatar
Phantom Phixer
Use Dexron III .
I've heard that some newer fluids that are synthetic can dissolve the glue used to bind the friction material to the clutch plates.
kevdog442
Feb 14, 2022 06:53 PM
JVCCutlass
Aug 8, 2021 03:59 PM
Lyle_STL
Jun 14, 2020 10:02 AM
Zacc
May 5, 2018 08:27 PM
jpc647
Jun 24, 2014 10:11 AM
