57 88 4 dr htp for parts ?
Hey guys I just came home with this 57 4 dr htp from a auction, I haven't decided what to do with it yet ? might cut off the rear clip to make couch and then part the rest of it out, to bad it is rough shape the floors are completely rusted away, all engine parts are there minus water pump. If I get some time I might mount the body up in my new rotisserie the Roller Hoop just to get some pictures and video of how well it works with big car bodies that need rust repairs.
Wow...man, it makes my heart sad to see this once beauty that way...this old girl has certainly had her day in the sun, quite literally. I went to a salvage yard a few weeks back and saw a few 57 Olds and was depressed for the rest of the day. Yours reminds me of that experience...but at least you have a some plan for it, instead of letting it sit and rust further away.
I think of the 57 Olds as a genuine piece of auto art, as well as history. It was one heck of a year for Olds. Their 60th anniversary year, What you have is a Golden Rocket 88. Too bad it is not deemed worthy of a restoral.
Good luck with it.
Dan
Good luck with it.
Dan
Last edited by Dan Wirth; Sep 5, 2009 at 04:33 PM. Reason: revised anniversary year: from 50th to 60th
Dan your right I'm still having a hard time after seeing about 40 old cars and trucks get crushed and a few were Oldsmobiles, I don't know anything about this 57 I have, what is a Golden Rocket ? rare? desirable? maybe it should be saved! here are a few more pictures from the sale I bought the 51 Chevy tin woody and the trailer load of frt clips, the other cars were not so lucky they got the crush!
I wouldn't call the car "rare" as it was a high production year for the car and there are still several in working condition. But I would refer to it as a true classic (even though there may be an argument from the Classic Car Club Of America in using this term). The word "Golden" Rocket 88 is used to celebrate Oldsmobile's 60th anniversary; no other year was given that term (please see my profile album for a 57 Olds restored. Also there are others in the master Album Directory of this forum).
Look at the engine and see if there are three 2-barl carbs or if there is one 4-barl. If it has three 2-barl carbs, you have the J2 induction option/version of the engine. This is sought after by most collectors and enthusiasts. The engine size for all options is 371 CID. With the J2 the HP is 300 (312 HP with racing option- very rare), from the standard 277 HP with the 4-barl carb.
I like that you have rescued this old beauty. It sure nice to see one out of the salvage yard and into someone's yard!
I've provided some reference history below that may also be of interest:
Additional Specs
ENGINE: Rocket 88, 371.1 cu. in.
Tri-power (J2 Option)
300 Horse Power
In 1957 Olds offered the J-2 option, three 2 barrel carburetors and a low restriction air cleaner, for just $83 (in 1957). This boosted the hp from 277 to 300.
Zero to sixty miles per hour in under eight seconds!!!!
America's first Muscle Car.
Weight: 4,283 lbs
Original Sticker Price: $3,447 + $83 (J-2)
The 57 Olds Super 88 J2, has 3 two barrel carbs and intake manifold #571175.
371
371s were produced from 1957 through 1963. Bore was now 4.0 in (101.6 mm) and stroke was increased to 3.6875 in (93.7 mm) for 371 cubic inches (6.1 L). 1959 and 1960 371s used green painted valve covers. 4-barrel models used 9.25:1 compression in 1957 and 10:1 in 1958 for 277 hp (206 kW) and 400 lb·ft (542 N·m) and 305 hp (227 kW) and 410 lb·ft (555 N·m) respectively. A 1958 2-barrel version was still impressive at 265 hp (197 kW) and 390 lb·ft (528 N·m), but had problems with early camshaft failures due to the high preload valve spring forces. Then, power nosed downward for the 1959 and 1960 88 model: 270 hp (201 kW) and 390 lb·ft (528 N·m) for 1959 and 240 hp (178 kW) and 375 lb·ft (508 N·m) for 1960.
The 371 was also used in GMC trucks.
Applications:
The 1957 and 1958 J-2 Golden Rocket had three two-barrel carburetors with a vacuum-operated progressive linkage. Only the center carburetor was mechanically connected to the throttle pedal, and it was the only one equipped with a choke. When the center carburetor was opened to 60° or more engine vacuum drawn from the windshield wiper pump would simultaneously open the front and rear carburetors. These carburetors did not open progressively; they were either open or closed. The J-2 engine also had a slightly thinner head gasket, raising compression to 10.0:1. It was advertised with gross power and torque ratings of 312 hp (232 kW) @ 4600 rpm and 415 lb·ft (562 N·m) @ 2800 rpm. Oldsmobile charged $83 for the J-2 option.
In practice, owners who did not regularly drive hard enough to engage the front and rear carburetors experienced problems with the linkage and carburetor throats becoming clogged, and some J-2-equipped cars had the front and rear carburetors removed and blocked off. The package was expensive to produce, and Oldsmobile discontinued it after 1958.
Oldsmobiles were given a new body for 1957 that further displayed the rocket theme with rockets above the headlights and jet engine taillights. Under the hood, the hot J-2 engine option offered plenty of 'rocket' power. This 312 horsepower V8 was immediately successful in the stock cars of Lee and Richard Petty. The engine was soon banned from NASCAR causing Oldsmobile to end its stock car racing[IMG]file:///C:/Users/DANIEL%7E1/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif[/IMG] team.
Oldsmobile celebrated its 50th anniversary in 1957. To mark the occasion, the base series was re-named the 'Golden Rocket 88' and the engine color on all models was changed to gold.
The 1957 Oldsmobile was an all-new car from chassis to roof. Super 88 was the performance series, marrying the lightweight 88 body with uplevel appointments rivaling the top-of-the-line Ninety-Eight.
The J-2 included triple two-barrel carburetors, which bumped horsepower of the 377 cubic-inch Olds V8 from 277 to an even 300. Of the approximately 385,000 Oldsmobiles built for 1957, just 7,128 were Super 88 Convertibles.
1957 Oldsmobile Super 88
by the Auto Editors of Consumer Guide
Oldsmobiles weren't raced much by 1957 and didn't need to be, having become consistently good-selling medium-priced cars known for innovation, as with the 1957 Oldsmobile Super 88. Even so, one Lee Petty and his son Richard drove Olds convertibles on the sands of Daytona and hardtops at other stock-car venues. And if a little heavy in street form, a '57 Olds could still be quite rapid with a new performance option called J-2.
300 Horse Power
Weight: 4,283 lbs
371
Applications:
- 1957-1960 Oldsmobile 88
- 1957-1958 Oldsmobile Super 88
- 1957-1958 Oldsmobile 98
Last edited by Dan Wirth; Oct 12, 2009 at 07:58 PM. Reason: to provide additional info/correction 50 year anniversary to 60.
Dan
Thanks for the overload of info. WOW ! you are the man ! my car just has a single 4 bbl but it still looks to be in good condition
Thanks agian for your help and info. if you ever need a rotisseie for your next project, check out my new rotisseries at www.rollerhoop.com I'm more of a sheetmetal repair kinda guy.
Auto Doug
Auto Doug
Dan your right !
After spending thirty some plus years doing restoration work on classic cars body this is the only way I'll do them any more, here is a picture of a 63 Galaxie simaler in size.
Hopefully I can get caught up this winter and tear the 57 Olds down and mount the body up in the Roller Hoop. I'll post it here first. theres a picture of my 48 Olds 98 fastback kinda rare I guess ?
I don't think you'll be disapointed restoring your Olds, it's unique in every way. And I used to like the 57 Chev best...not anymore!
By the way, can you expand the loops on the rotisserie to accommodate larger cars or do you simple use larger loops?
Dan
Dan
Dan the standard Hoops will acomedate most body shells, but an custom 7' 9" Hoop should handel the largest of body shells. here are some pictures of a 69 Super Bee in the standard Hoops (7' 3" ) penty of room to operate and to work
autodoug - there is one item in the reference material I sent you above that needs some clarification and that is about the J2 Option for the 57 Olds. There were two J2 Options. One for racing, which was rare, and one that was common to the marketplace. Please see a forum response below (not neccesarily from this forum):
What is the difference (if any) between the 300hp and 312hp versions of the 371 with J-2 option? How can I tell by looking at the engine? Thanks!
Re: J-2 Option
The 312 hp version has/had a solid lifter cam with adjustable rockers. the rocker covers are dimpled to allow for the extra height needed for those rocker arms. Outside of that I'm not sure of any other difference. you will have a very difficult time seeing one as few were produced and were used in racing, nascar I'm told. Folks that have been around longer than I have said they've seen none or maybe one. I've heard of 2. Authentic?? The Feb 57 Hot rod has one on the front cover in color. 300 hp is what you see in cars for sale, intakes-carbs on ebay. I have a 300hp/smooth rocker covers J2 in a 57 2dr 88 coupe. Have 2-3 extra intakes I've accumulated.
The J2 Option: 300 HP Vs. 312HP
Re: J-2 Option
Hi Dan,
Thanks for posting all that info. I am currently working on a 57 - 4dr hdtp with the J2 package. I just got it fired up about 2 weeks ago after sitting for about 25 yrs.
The car is in quite good shape. I have to get the brakes sorted out and the wiring has some issues too. Eventually, the wiring will be completely redone. After the brakes are ready then its on to the exhaust system.
Hopefully, I will have it on the road next spring and hitting some car cruises.
