1949 Olds 88 distributor
Old Jun 23, 2021 | 08:43 AM
maineolds's Avatar
Hi everyone, I sent my original Delco 1110814 distributor to https://www.northstarautoelectric.com for service. I've had them do work in the past and was very pleased with the results and customer service. My distributor has been a bear to make right, because tech specs weren't available to Northstar, so I ordered a rebuilt distributor from Fusic http://www.fusickautomotiveproducts....s.asp?dept=480. What I got was a different distributor than my original. Fusic sent Delco 1110817. A little research shows that my original 1110814 was superseded by 1110817. http://www.delcoremy.com/find-a-part...etails/1110814
Ive got no issues using the rebuilt replacement, but I'd like to hear from anyone that has had both units. The internals are different. Very different. Why? What was the problem with the early model?
Thanks for the feedback.
Nathan
Old Jun 23, 2021 | 09:57 AM
rocketraider's Avatar
Oldsdruid
Didn't your original have that octane selector plate? Does the new one have that?
My guess is the mechanical advance mechanism may be different.
Old Jun 23, 2021 | 10:16 AM
maineolds's Avatar
No octane selector plate on the original. The differences are with the mechanical advance. The early distributor uses different internals for sure. I don't know what's what inside but I'll post pics with the differences asap
Old Jun 24, 2021 | 06:58 AM
Tedd Thompson's Avatar
let ne try and answer this, a little handy caped today, any first generation distributor between 1949 and 1956 will interchange There are differences but all will work Just fine 1956 being the best because of the dwell window adjustment in the cap. Unless this is a concourse car no one will know the difference. Hell they won't know the difference at a concourse...... Tedd
Old Jun 24, 2021 | 09:36 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I put a 56 distributor in my 54 and it was a great improvement. I hate those old distributors. They are a PIA.
Old Jun 29, 2021 | 11:47 AM
57JoeFoMoPar's Avatar
You can even use the distributor out of 371 or 394 if you swap the drive gear.
Old Jun 30, 2021 | 03:21 PM
maineolds's Avatar
thanks great info to know! Thanks. When I get home from a business trip I hope my distributor is waiting for me! It will FINALLY be time to drive!
Old Jun 30, 2021 | 06:16 PM
The earlier distributors use a "single D" oil pump drive whereas the later engines have a hex oil pump drive. Just drive the pin out with a punch, swap the gear, and hammer in a new pin. The factory pin will be solid, but a basic roll pin will work just fine and is an acceptable replacement, as it is an acceptable replacement for a SBC.
I used the distributor from a '61 394 in the '55 324 in my '56 Holiday 98, which had a Pertronix already in it. To be on the safe side, I put a small roll pin within the bigger roll pin when I swapped the drive gears and put a tack on it with a TIG. 7000+ miles so far so good.
Dec 14, 2018 01:54 AM
oldsmobilty
Sep 28, 2016 06:44 PM
FStanley
Jul 27, 2016 07:27 AM
rcrac3r
May 10, 2012 09:34 PM
4-ever-olds
Oct 3, 2009 08:51 PM
