Progress on the project(1948 98)
Old Nov 2, 2018 | 05:24 PM
FuturamicOldsmobile's Avatar
I’m happy to say that I have rewired the headlights,running lights,horns,coil and generator I am yet to test it but I expect no problems. Look ma no wire nuts now
Old Nov 3, 2018 | 07:11 AM
RetroRanger's Avatar
72 Olds CS
Nicely done wire nuts under the hood look silly.
i never have good luck w the crimped on ring terminals, half the time I give the wire a tug and out it comes or I can feel it's loose. To get around that I remove the plastic sleeve solder the ring terminal on and use apiece of heat shrink where the plastic sleeve was.
Old Nov 3, 2018 | 08:00 AM
RandyS's Avatar
In most cases, you can pull the plastic insulator off of the end of the terminal. solder the joint, then slide the sleeve back over the terminal. Very clean looking terminal that won't ever come apart.
Old Nov 3, 2018 | 09:49 AM
I would have soldered them but I don’t have a way to use my weller at the cars location.
i also used vice grips to squish the butt connectors.
Old Nov 6, 2018 | 09:59 PM
It’s alive
Old Nov 6, 2018 | 10:01 PM
I
Old Nov 7, 2018 | 07:31 AM
47 Convertible's Avatar
Good for you. Progress is so satisfying. Don't let the momentum die.
Jerry
Old Nov 7, 2018 | 08:33 AM
Jerry
oh believe you me I won’t
Old Nov 7, 2018 | 08:34 AM
Thank you all
friesjh
Sep 18, 2019 07:09 PM
jensenracing77
Feb 9, 2019 02:31 PM
kevdog442
Jan 13, 2019 09:04 AM
72455
Dec 25, 2018 01:22 PM
jurrasicpork
Aug 16, 2018 12:25 PM
