Removing tool for 1955 bezel ignition
Old January 8th, 2021 | 05:22 PM
Pat55Olds's Avatar
Hello, and Happy New Year to all... well if 2021 is less sh***y than 2020, it will be already great.
I'm wondering what tool you are using to remove the bezel of the ignition switch on a 1955?
Old January 9th, 2021 | 10:04 AM
Tedd Thompson's Avatar
I don't remember using any special tool. Isn't there a small set screw on the bottom of the benzyl that allows it to be removed? I could be thinking of the wiper benzyl, it's been a while sense I've been there....Tedd
Old January 9th, 2021 | 11:49 AM
Charlie Jones's Avatar
Phantom Phixer
There is a small round hole near the keyhole on the face of the lock cylinder .
Get a paperclip and straighten one end of it .
Put the key in the ignition and turn it to the left ( counterclockwise ) .
Push the end of the paper clip into the small hole .
Keep turning the key all the way to the left .
You may then pull the lock cylinder and key out of the switch .
After that you can unscrew the bezel from the switch and remove the switch from the back of the dash .
Old January 10th, 2021 | 02:05 PM
Pat55Olds's Avatar
It worked, thank you very much to both of you for your help!
Old January 10th, 2021 | 02:06 PM
Pat55Olds's Avatar
Thanks Tedd
Old January 10th, 2021 | 07:49 PM
Charlie was THE MAN on that one...... Tedd
Old January 10th, 2021 | 08:02 PM
Phantom Phixer
Thanks , Tedd .
I think I learned that trick from a mechanic at my local Chevy garage when I was about 16 .
This works for all '35 thru '66 GM cars .
Old January 11th, 2021 | 09:23 AM
Pat55Olds's Avatar
Charlie was the Man, but you got the supportive award
TheGageinator
April 14th, 2020 03:14 PM
Tiger69
Ninety-Eight
May 8th, 2018 08:22 PM
53Ragtop
April 11th, 2017 03:55 PM
Trailrunner
April 15th, 2016 05:58 PM
yeahbuddy
February 3rd, 2010 05:39 PM
