Removing Standard Brakes Master Cylinder - 57 Olds 88
Old Aug 18, 2024 | 05:38 PM
57olds88's Avatar
Has anyone removed a standard master cylinder from a 57 Olds 88 (or something comparable)? I removed the two bolts and the brake line, but I cannot figure out how to disengage the pushrod sleeve (clevis) from the braket. Do I have to remove the entire brake pedal assembly? I've replaced several master cylinders in 60s and 70s cars (apparently when engineers harbored less hatred for mechanics).Thanks in advance!
Old Aug 19, 2024 | 09:09 AM
Charlie Jones's Avatar
Phantom Phixer
Here are some illustrations that may help.
I would think that removing the pin from the clevis on the pedal would be the easiest
1956 setup is similar to 1957.
Click on pictures for larger version.
This is the master cylinder exploded.
Old Aug 19, 2024 | 11:06 PM
57olds88's Avatar
Thank you!
Zabbs22
Brakes/Hydraulic Systems
18
Jan 21, 2023 03:35 PM
mbat
Apr 12, 2021 07:40 AM
griffey57
Apr 2, 2021 11:10 AM
New2Olds57
Jun 23, 2014 06:39 PM
karlskorner
18
Jul 24, 2012 07:24 AM
