Power Steering Pulley Removal- 56 Olds 98
Old Jan 24, 2026 | 06:28 PM
klowery88's Avatar
Hi there. I’m installing a new steering gear box and rebuilding the power steering pump on my 56 Olds 98.
I’m having a bear of a time with the pulley on the power steering pump. The manual says “remove the pulley” and doesn’t list specialty tools or anything like that. has anyone else figured out a trick to getting this thing off? There’s no lip on the nose of it to slide a puller on there like the 60’s/ 70’s Chevys I’ve worked on.
Thanks for the help! Trying not to mess this pulley up.
Old Jan 26, 2026 | 11:14 AM
klowery88's Avatar
Just to close the loop… I soaked it in penetrating oil overnight, and holding the pump off the work bench by the pulley and tapping the shaft with a hammer got it free. I think it was just rusted on there. A little oil on re-assembly and it went back together without difficulty.
Old Jan 27, 2026 | 08:53 AM
newmexguy's Avatar
bolt on versus press on
"press on" pulleys on Saginaw Gm pumps started in the mid seventies. Before that, they were "bolt on".
Old Jan 29, 2026 | 03:43 AM
Glad you got it.
66luvr
Oct 17, 2022 08:41 AM
68442
May 19, 2022 02:48 PM
EsoWuhn
Nov 10, 2019 09:00 PM
mother$hip89
Sep 24, 2019 04:27 PM
The Flash
Apr 21, 2014 11:03 AM
