Piston
Old Nov 3, 2021 | 01:49 AM
mais18's Avatar
Piston
Hello,
I'm looking for 6 pistons for my 1949 L6 oldsmobile (original dimension)
Thank you for your help
Old Nov 3, 2021 | 03:01 AM
35olds's Avatar
I'd suggest contacting Egge Machine Co in California. Surprisingly they don't list them on their website but certainly worth asking. If they can't help then Australian manufacturer JP Pistons (Nornda Group) will make them and they are distributed in the UK by F.W Thornton who might be a bit closer to you.
https://egge.com/product/kits.php?ac...engine=257+CID
https://www.norndaautomotive.com.au/...,%20CR%206.5:1
https://www.fwthornton.co.uk/jp-pistons-blog-8
Old Nov 3, 2021 | 04:03 AM
BillK's Avatar
The first place I would check would be Egge Machine
https://egge.com/
Old Nov 3, 2021 | 05:50 AM
mais18's Avatar
thank youI am going to ask
Old Nov 3, 2021 | 05:51 AM
mais18's Avatar
I am going to ask
Old Nov 3, 2021 | 07:17 AM
mpolds's Avatar
The L A S T place anyone should check is egge machine --- they are usually double and triple the price of everyone else.......
I may have them Brand New--- N.O.S. very U.S.A. made ---
Always best to simply call me--- 516 - 485 - 1935 --- Craig.... New York...
Old Nov 3, 2021 | 07:18 AM
mpolds's Avatar
I see that you are from France... Bonjour....
Let me know right here on this thread or with a P.M. that you want me to investigate.... Craig....
Also, of course, Standard or Oversize.... Merci.....
Old Nov 3, 2021 | 07:30 AM
mais18's Avatar
thank you i can't call you i don't speak english
but you can do some research for me it's ok
response in P.Mthe pistons are in standard size
Merci
Old Nov 3, 2021 | 07:41 AM
mpolds's Avatar
.C'est d'accord..... No phone call necessaire....
I will see if I have them for you... A Bientot...... Craig.....
(Je parlais le Francaise, mais seulement un peu, et aussi, il y a long temps que j'etudier!!!)
Old Nov 3, 2021 | 10:24 PM
Ozzie's Avatar
Merci
If it's needed, for the standard pistons, the group number is 0.629 and the part number is 557100. They were available also in oversizes: .003, .005, .010, .020. and .032 inches. The pistons were supplied with the pins.
Old Nov 11, 2021 | 04:44 AM
mpolds's Avatar
I can provide you with only two (2) standard pistons only.... seulement deux ....
Je suis desolee, mais seulement le deux.....Merci, Craig....
mais18
Nov 3, 2021 05:51 AM
60193W30
Dec 1, 2020 03:21 AM
72hurst
Mar 1, 2012 03:35 AM
greencadillacmatt
Apr 8, 2009 09:36 AM
oldsracer67
Dec 16, 2008 01:53 PM
