How does she sound?
Old September 22nd, 2012 | 06:58 AM
CO53Super88's Avatar
How does she sound?
Here's a quick video of my '53 idling after a long drive. How does the old 303 sound (bearing in mind she has 108k miles on her )?
Old September 22nd, 2012 | 07:23 AM
z11375ss's Avatar
Senior Moment Member
The link doesn't link. Try going to the video and copying and pasting the link as it appears exactly on the address in the taskbar. If you copy it and paste it, it should work.
Old September 22nd, 2012 | 07:46 AM
Ok, thanks for the heads-up ... should work now.
Old September 22nd, 2012 | 07:49 AM
Runs good.
Old September 22nd, 2012 | 08:06 AM
redoldsman's Avatar
Proud Viet Nam Veteran
It seems to be running very well. I hear a little bit of valve train noise which is common with one of these engines with some miles on it. I have never seen an air cleaner like that.
Old September 22nd, 2012 | 09:07 AM
It was made by Fram and was installed prior to my dad buying the car in 1976. It uses a replaceable paper filter element. Seems to work but it drafts via an airgap around the bottom so I would imagine it's drawing warmer air off the top of the block which has to hurt performance. I have the original oil bath air cleaner and might look into modifying it to accept a paper element.
Old September 22nd, 2012 | 09:38 AM
TripDeuces's Avatar
Is that the original shroud? Looks like it's made out of Bakelite?
Old September 22nd, 2012 | 09:59 AM
The fan shroud is metal and, yes, as far as I know - or can tell - it is the original. The paint on the shroud matches the paint on the radiator, but I don't know if that's factory or if they were both repainted at some point.
Old September 22nd, 2012 | 10:21 AM
Highwayman's Avatar
Originally Posted by CO53Super88
....I have the original oil bath air cleaner and might look into modifying it to accept a paper element.
Is that a batwing like they used on 55 & 56? If so, take a look at this thread.
https://classicoldsmobile.com/forums...ing-324ci.html
Old September 22nd, 2012 | 10:27 AM
Yes I believe it is (large round cleaner with half-circle shaped openings on either side that point forward). That link is exactly the information I would need to convert - thank you!
Old September 22nd, 2012 | 11:33 AM
z11375ss's Avatar
Nice car.
Old September 22nd, 2012 | 12:26 PM
Nice car.
Thanks. By the way, love your gear-grabbing video. Looks like a fun car!
Wyze
October 13th, 2010 06:36 PM
rtanner68
September 21st, 2010 07:15 AM
MI455
December 9th, 2009 05:50 PM
Redog
April 4th, 2009 07:49 PM
HouTXCutlass
March 27th, 2009 12:49 PM
Quick Reply: How does she sound?
