horn button
Old May 14th, 2012 | 08:11 PM
oldolds88's Avatar
horn button
i ned to know how to get the horn button off from my 49 olds 88. the horn works, but you have to push the center so hard it sticks. it wont work from the ring. any advice?
Old May 15th, 2012 | 09:13 AM
Tedd Thompson's Avatar
I know nothing of a 49 Olds but on a 55 if you tighten or loosen the large steering wheel nut you can change the sensitive of the horn, that is if your insulating gaskets haven't deteriorated to the point there is no more smash in them , this may or not pertain to your problem but you might give it a look... Tedd
Old September 21st, 2012 | 03:18 PM
jlh's Avatar
jlh
The center button in the horn ring, that has the world under plastic, is removed by depressing it and turning it counter clockwise about one half inch then it should be easy to lift it out. You may have to use one of those thin rubber pads that you use to remove a jar lid. Good luck.
If this does'nt work, the only other way that I know of is to use a syringe and squirt laquer thinner around the outside of the chrome ring on the button (be very careful not to get any of the laquer thinner on the plastic face) . The down side to this method is that you will destroy the rubber donut under the botton that acts as the spring that holds the button in place and also acts as a vibration damper.
DennisG.
April 15th, 2012 11:01 AM
millwrightrice
September 2nd, 2008 08:09 AM
millwrightrice
Tech Editor's Desk
August 31st, 2008 06:04 AM
HAFROD
January 19th, 2008 03:57 PM
JPDPG
November 9th, 2007 07:27 PM
Quick Reply: horn button
