Finally Got Bendix Treadle Vac Fixed
Removed Unit From Car And Found Lots Of Fluid And "Gook" In Booster Housing As Well As in Master Cylinder. After Much Cleaning With Carb Cleaner,small Wire Brushes,Emery Cloth, We Honed The Walls That Were Pitted, Replace All Parts,reinstalled And Brakes No Longer Go To The Floor While Holding pedal Down For Long Periods Of Times. thanks For Everyone's Help And Advice (Rocketowner, Larry Jones)
Larry, Mine was a Morane system and it also failed at the junction of the master and booster,this seems to be the weak spot( if fifty years of service deserves to be called weak). Aren't they a strange looking system from the inside? glad to see you will be back on the road.....Tedd
Moraine and bendix brakes
1970VistaCruiser
November 22nd, 2012 04:55 PM
