'56 Heater Fan Resistor
Old Feb 9, 2016 | 03:37 PM
ignachuck's Avatar
Frank Ignachuck
My heater fan doesn't work on "high".
The shop manual shows a resistor that may be the culprit, but I can't find it.
Any one know where it is located?
Thanks, Frank
Old Feb 10, 2016 | 02:57 PM
Yellowstatue's Avatar
Look on top of the heater case under the dash. Usually mounted in air flow stream for cooling. Follow wires from fan switch to secret location.
Old Feb 12, 2016 | 07:27 PM
Ozzie's Avatar
You might also check continuity on the switch's high speed position and the wire going to the resistor(s). My wiring diagram shows the low speed using two resistors in series with the high speed using only one of the two used on low.
Old Feb 13, 2016 | 02:24 AM
ignachuck's Avatar
Frank Ignachuck
Thanks very much Yellowstatue and Ozzie. I just bought a spare switch just in case that's the problem. Finding another resistor might be a challenge. I know it's group 8.852/#3131533.
Frank
Old Feb 17, 2016 | 02:09 PM
ignachuck's Avatar
Frank Ignachuck
A little warmer here today so I ventured under the dash to find the resistor when I got home and there it is, in the heater box. Clear view of the terminals. Lots of corrosion on the connections. I'll clean them off next warm day and see what happens. I don't want to risk breaking off a brittle wire in the cold.
Thanks again Ozzie and Yellowstatue.
Frank
Old Feb 17, 2016 | 03:28 PM
ignachuck's Avatar
Frank Ignachuck
By the way, Yellowstatue also answered a similar question back in 2010. Thanks.
I'll have to remember to do a search in the future before starting a new thread.
Frank
Old Feb 17, 2016 | 06:04 PM
I don't mind re-answering questions, over and over...it keeps me awake.
Old Feb 22, 2016 | 02:33 AM
ignachuck's Avatar
Frank Ignachuck
I was able to reach in and clean all the connections. All set now. I wish everything on this car was that easy. Thanks again.
Frank
Old Feb 23, 2016 | 06:26 AM
WHIPOLDS's Avatar
Frank - My switch does not work on low but it does on high. Thank you for pointing me in the right direction for a fix.
Rick
Old Feb 23, 2016 | 11:42 AM
Eightbanger's Avatar
No high speed on my 53, when I turn it on it glows red...
Old Feb 23, 2016 | 04:03 PM
ignachuck's Avatar
Frank Ignachuck
Here is the thread from 2010 that I referenced above. It may help.
https://classicoldsmobile.com/forums...-resistor.html
Frank
Old Feb 23, 2016 | 04:36 PM
Frank
Thank you for that Frank.....I had put this issue on the back burner to get some other bigger jobs done first, then I spotted your thread.
I still need to remove my resistor as you had done and clean the whole thing up and see if that helps, I can't imagine these coils were meant to glow red, get hot perhaps but surely not red, it's a fire hazard and what if a kid ever put their hand in there they'd get seriously burned.
W-27
Jul 23, 2015 07:55 AM
amercer7155
Jun 13, 2014 12:10 PM
5998DownUnder
Jun 9, 2014 09:35 AM
dan2286
Feb 5, 2009 06:42 PM
david adelberg
Jun 2, 2008 06:10 PM
