56 headlight swith
56 headlight switch
Looking for a headlight switch for a 56. I am thinking of trying a different year if I can't find one reasonable.
Fusick have them;
http://www.fusickautomotiveproducts....number=1995074
I was going to say that '55 and '56 were the same but they made one especially for cars equipped with " autronic eye or self dimming headlights". Ebay has a universal 12 headlight switch (for 1956 Olds) that does have the rheostat built in for dimming your interior lights and it's only $18.00. The **** has a set screw where you take it off to install it through the dash. Larry
I'm not looking for new since I have seen most close to a hundred bucks.Just looking for a used one that works or if somebody has used another year or model for replacement. I know Fusick has them but too expensive for me.
The correct part number is 1995062 (group 2.485). Fits 55 and 56 without autronic eye. It has "062" stamped on it. I've seen references to 1995074 and 1995077, which are for 57's and 58's. They may fit as well. I couldn't find a cross reference to other GM's.
Frank
Frank
Thanks for the info I will check into it.
droptop442
August 10th, 2009 07:52 AM
droptop442
August 10th, 2009 05:43 AM
Richie
February 14th, 2005 02:49 PM
