55 olds dashboard
Old Jan 14, 2024 | 06:15 PM
Super88chris's Avatar
55 olds dashboard
Hey all just curious, I got the shop manual for my 55 olds super 88 but it doesn’t say that can take off the top of the dash, it showed a picture of the dash plate grill that can come off, I was hoping someone would know if just the top part can come out? So I can look down in there at all the wires and hoses, I’d like to replace all vacuum lines and make sure wires are set up correctly
Old Jan 15, 2024 | 12:35 PM
justacog's Avatar
I don't know if you can. What I've done is to just remove the glovebox insert and detach the vent hose to access all of that fun stuff under there. I ran new vacuum lines to the windshield wiper control, replaced the heater control valve and hoses, and just general inspected everything else that way.
Old Jan 15, 2024 | 01:02 PM
hmm yeah I might just do that I just don’t want to take out all instrument panels since they work and mess things up ya know. I especially don’t want to be taking apart pulley systems
Old Jan 24, 2024 | 07:50 AM
madmax442.com's Avatar
madmax442.com
I did the same on my 1955, remove the glove box and you will have plenty of space. There is that support channel up in there you need to route the new hoses through, but it wasn't too terrible.
Old Jan 24, 2024 | 07:55 AM
ok I will tackle it that way. Next question, the chrome plate right behind the speedometer needle is loose and I’m missing that needle on the gauge and my Speedo cable is hooked up but how would I get at that chrome plate and see why the needle isn’t moving when I drive??
Old Jan 24, 2024 | 04:56 PM
madmax442.com
Chris, do you not have a 1955 Shop Manual yet? The instrument panel and diagram is on Pages 14-1 - 14-2.
$37 bucks here: https://www.themotorbookstore.com/1955-oldsmobile-shop-manual.html?gad_source=1&gclid=Cj0KCQiAh
8OtBhCQARIsAIkWb69q9QmJu6yYj_LUv0C5KhmJ-0h8Pa81RbkHM9XD6gVufNNbC8z2UhwaAiG1EALw_wcB
Old Jan 24, 2024 | 05:00 PM
Originally Posted by Super88chris
...I got the shop manual for my 55 olds super 88...
Good chance....he does.
Old Jan 24, 2024 | 05:03 PM
Old Jan 24, 2024 | 05:37 PM
I got it thanks
Old Jan 24, 2024 | 06:23 PM
2blu442's Avatar
I've got an extra speedometer assembly and parts from another. If you need to replace anything I might be able to help. John
Old Jan 24, 2024 | 06:27 PM
heck yeah! That would be awesome! Like I said I know I’m missing the needle on the gauge. Hopefully soon I’ll get a chance to pull out the cluster and check to see if it will still function. What’s your email incase it’s no good
Old Jan 24, 2024 | 06:47 PM
2blu442's Avatar
PM sent.
Old Jan 25, 2024 | 05:36 AM
Bfg's Avatar
Bfg
I have a nice dash pad if your interested
Old Jan 27, 2024 | 03:55 PM
DFitz's Avatar
74 2.8L Capri
I had this exact same thing happen.
There are outfits that will rebuild speedometers Unfortunately, they are not cheap. There are a couple of issues:
1. The speedometer is balanced for the weight of the needle. My needle fell off and was sitting at the bottom of the gage. It fell off because it was bouncing around when driving. Which meant the gears in the speedometer were worn. You can't just glue the needle back on, it will change the weight, and therefore what speeds are indicated while driving. The rebuilders do a good job of balancing the repair.
2. Since the gears were worn, they need to be replaced. The rebuild places generally do a good job. It could also be a worn speedometer cable. They are pretty reasonable new from Fusick.
3. When you take out the instrument cluster, be very careful pulling the wires out. Believe it or not, each wire is color coded, and there is a paint mark on each connection, on the back of the cluster, that matches the color on each wire. I used masking tape and numbers.
4. While you have the cluster out, go ahead and replace all the light bulbs. I think there are 2 different kinds. If I remember correctly, the bulb for the high beam is different, slightly smaller, turn signals too. The internal lighting bulbs are all the same. Cheap and any auto parts store.
Dave
Old Jan 27, 2024 | 05:02 PM
Dave
thanks Dave I’ll keep all that in mind. I did notice my speed cable wasn’t hooked up so I hooked it up when for a drive and it sounded terrible the speedometer was moving but loudly and all over the place. The silver plate behind the needle is definitely not hooked up so that is most likely one issue. I want to pull out the cluster but when I start I get overwhelmed cuz everything in there works besides the obvious and I don’t want to ruin something that is currently working
Super88chris
Dec 23, 2023 07:02 PM
dc2x4drvr
Nov 8, 2021 03:05 AM
venividivici53
Cars Wanted
Jun 19, 2013 08:52 PM
starman63
Apr 27, 2013 08:16 PM
jozw30
Jan 9, 2011 05:58 AM
