53 Timing Chain
53 Timing Chain
Received my new Cloyes timing chain, went out to the car excitedly to install it and it doesn't fit![Mad](https://classicoldsmobile.com/forums/images/smilies/mad.gif)
Been through Rockauto's return procedure and it seems they're not liable as they sent what I ordered, and i'm not liable as I ordered correctly.![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Not sure how to proceed as far as getting the correct timing chain, because it wasn't as if there were loads to choose from when ordering...how the heck am I going to find the correct chain?
Edit; just found out Autozone have another chain pt# C373 listed along with the chain I received from Rockauto C494, both are listed as fitting the 88 but not the 98
the C373 on Summit and O'Reilly aren't even listed as fitting a 53 Olds, they are listed as fitting the 1980's Cutlass.
http://www.autozone.com/internal-eng...deluxe-88/1953
So on a 63 year old engine, your just going to replace the timing chain and nothing else while the front cover is off?? Do it right- get the three piece set and don't mix a new chain with gears that have a wear in them. If you want a GOOD set, Ross Racing has a double roller set for the early Olds
Cloyes web site lists the C-494 for 53-98 303? V-8. After motor 8A-288505
They list the gears separate.
They have a tech line.http://cloyes.mycarparts.net/
Gonna ring them tomorrow and discuss this, anyone know what the term "After Motor" means?
Curious incase it was the timing sets that were changed.
The running change in question was the timing chain.
The engine number should be stamped (not cast) on the left cylinder head above the center exhaust port.
I think that if the chain and gears are all changed as a set you will be OK.
Here's my engine number.
And don't forget.....
And don't forget, Nigel, if you need, I deal with a manufacturer of timing chains and gears ----
So I can get you some nice N.O.S. Very Very U.S.A. made Timing Chains
and Timing Gears.... Steel, of course, and not Nylon,
and a perfectly matched set....
Library is closed this weekend, as it is our Memorial Day Weekend -- a tribute to our armed forces worldwide, past and present...
Yours, Cheers, Craig..................
I don't know if I'm adding more chaos to confusion, but here's what's in the Olds parts book:
Group 0.724 Chain, Timing
1949-1956 8-Cyl.(64 links 13/16" wide - double flanged side guide type) part 557396
1950-1959 8-Cyl.(48 links 11/16" wide - single flanged side guide type) part 559446
Group 0.728 Gear, Crankshaft Sprocket
1949-1956 8-Cyl. (24 teeth side guide type - gear teeth offset & 1/2" wide) part 557395
1950-1958 8-Cyl. (18 teeth side guide type - gear teeth offset & 17/32" wide) part 559445
Group 0.736 Gear, Camshaft Sprocket
1949-1956 8-Cyl. (48 teeth side guide type - gear 1/2" wide) part 557394
1950-1958 8-Cyl. (36 teeth side guide type - gear 17/32" wide) part 559444
This was shown in the Oldsmobile Parts Book dated 1958, effective 1 January 1958.
The catalog listings for some of these outfits may be a bit confusing. You may have to "read between the lines", use some interpretation, and depend on physical dimensions.
I still think if the gears and chain are replaced as a set everything will be OK .
There were no differences in camshafts or crankshafts.
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
Mine has....
Camshaft Gear 48 teeth
Crankshaft Gear 24 Teeth
Thanks guys.
The cam gear you have is cast iron (and not steel) as is usual. It shows a bit of wear from the chain, but this is normal. Does the replacement chain which you received have a different number of links and a different width from the original? If so, you just got the wrong one. With the correct chain, you could have installed it, and all would have been well. If that bit of wear on the gear(s) bothers you, you can replace it/them also. The chain will then be a bit tighter. Most of the slack in a slack chain is caused by wear in the links of the chain. As Charlie said, you can also change the gears, if you want; the cost should not be excessive.
