303 oil pan gasket install
Old Jan 17, 2021 | 10:34 AM
maineolds's Avatar
Anyone have some tips for installing an oil pan gasket set for a 1949 Olds 88 with 303v8? I’ve got the Fel-Pro OS6412C gasket set. It comes with a left and right side cork gasket, two small cork gasket blocks (no clue what these go to), and a front and rear rubber gasket. I’d planned on using Indian Heat to shellack the cork gaskets in place on the pan. Then use Hylomar on the other side of the gaskets where they contact the engine.
My big question is, what are the small cork blocks for? What order do I place the front snd rear gaskets in? Before or after I secure the sides? Another question seems kind of silly. The only way the gasket lines is if I have the left side up (paint showing) and the right side down (gasket paint face down). Does this seem right?
Old Jan 17, 2021 | 02:39 PM
Tedd Thompson's Avatar
To start off with the two small cork gaskets are for the rear main seal, don't loose them you will need them for sure. Use RTV on each corner there and don't trim them though they look to long As far a the printed or non printed gasket material it doesn't make any difference. I haven't used shellac in years, worked then but there are better things now a days. I have used RTV and spray contact cement or Permatex on occasions depending what I'm sticking down or sealing up....Tedd
Old Jan 20, 2021 | 04:05 PM
maineolds's Avatar
Can anyone tell me why there are gaps on the ends of the rubber seals on the oil pan? The seals kind of ramp up at the ends. That causes them to rise above the actual pan. Won’t this leak?
crazy thing is, the originals appear to do the same thing. (In the pics, the gaskets in my hand are the old ones). The old seals “ramp”/gap isn’t as big, I assume because once the pan is installed it snugs down. Should I apply any RTV type sealant to these gaps on the ends? This looks crazy. Sadly I can’t get under the car to see how this will all fit together until I finish the timing cover install. My engine is supported by a bottle jack and I can’t slide underneath till it’s gone. Here are some pics to explain.
Old Jan 20, 2021 | 04:19 PM
zzcruzin's Avatar
Those are the wrong rubber seals. I just did mine last week and the felpro gasket set is not right. You should have two like the ones you show and there should be two that do not have the extra bumps on the ends. In other words the right ones are slim all the way from one end to the other. Someone needs to notify felpro about this. They never use to be like that.
Old Jan 20, 2021 | 04:22 PM
maineolds's Avatar
Oh that’s awful news! Still, I’m glad I asked. Where did you get the correct seals?
Old Jan 20, 2021 | 04:25 PM
zzcruzin's Avatar
What you could do and i have done it, is to take a sharp razor blade and trim that hump out of there but trim around and leave the rubber plug that goes in the hole of the pan. I also use black rv silicone at the corners where the rubber meets the cork. As for the colored cork, you have them right. They just dont color match them the way they are mounted. Just curious, did you find much sludge in the bottom of the pan? Mine was very ugly. Al those years of non-detergent oil which i will never use.
Old Jan 20, 2021 | 04:27 PM
zzcruzin's Avatar
You can trim those like i said or any auto parts should be able to get you some. Just look at them before you leave the store. I don't know how felpro has not been notified of this. I bought another set about a year ago and they were right.
Old Jan 20, 2021 | 04:29 PM
zzcruzin's Avatar
I also like indian head.
Old Jan 20, 2021 | 04:32 PM
zzcruzin's Avatar
See if this helps. Look at the two kind of rubber seals. Good thing you asked and did not proceed.
Old Jan 20, 2021 | 04:33 PM
zzcruzin's Avatar
I think the manufacture of "best gaskets",,, is the best.
Old Jan 20, 2021 | 04:36 PM
maineolds's Avatar
If I can’t locate the correct seals I’ll trim them down. Regardless of what rubber seals I use, should I put them in dry or apply a sealant under them?
Old Jan 20, 2021 | 04:46 PM
zzcruzin's Avatar
I put thos in dry so they don't try to squeeze out when tighting the pan. If you razor blade them down, you coud just smear a very small amount of sealer at those to end points just to be safe.
Old Jan 23, 2021 | 05:03 AM
maineolds's Avatar
To start off with the two small cork gaskets are for the rear main seal, don't loose them you will need them for sure....Tedd
Tedd, if I didn't have a leak from the rear main seal before removing the oil pan, is there any reason to take things apart to install the two small cork gaskets at the rear main seal now?
Old Jan 23, 2021 | 07:12 AM
If there is no leak before I would just give them a dab of RTV and let them be reused...Tedd
Old Jan 23, 2021 | 07:39 AM
maineolds's Avatar
I’m a little confused by the whole thing because I don’t see the originals or where those little Square cork gaskets would even go on the pan. Without removing more than just the pan, there does not seem to be a place for them. I’ve heard they go to the rear bearing seal, but that’s not exposed with the pan off that I can see. I’ll take a pic later today if what I see with the pan off
Old Jan 23, 2021 | 08:05 AM
zzcruzin's Avatar
They go in the rear near the seal. I did not use them as mine was fine when i took the pan off. You probably don't need them, but your choice. When i put the gaskets and the rubber seals on the pan, i use a dab of silicone sealer on all four corners where they meet. I have a question. I see your oil pickup tube with the wire installed in it. There is suppose to be a screen in there and the wire holds it in place. Did you happen to take the screen out? Or was there one? I hope there was one there.
Old Jan 23, 2021 | 08:12 AM
maineolds's Avatar
Good catch! I took the scream off for cleaning. I’ll be sure to reinstall. There wasn’t a lot of gunk in the pan, but there was some. So where do the square corks go? What would I need to disassemble to see them? I think I’ll leave it alone but I’d like to know just the same. I appreciate the help.
Old Jan 23, 2021 | 08:27 AM
zzcruzin's Avatar
Glad you have the screen. Mine was very dirty and clogged up, not to mention the thick gunk in the bottom of the pan from all those years of running non detergent oil. It will never see that kind of oil again. Maybe someone will correct me, but if you look up in there at the rear main seal at the crank, i think that is where those small square cork peices would go if you need them. Mine was pushed up in the block about 1/16 past the face off the block and i seen no need for them. If there was more gap between the bottom of the seal and the face of the block, then perhaps they could be used and trimmed down to fit. Like i said earlier, i just used a small dab of silicone in there and i have no leaks.
Old Feb 18, 2021 | 06:39 PM
Matthew Saliba's Avatar
Plan to do oil pan gasket replacement 1950 98.
Any advice. What will I need to remove to be able to remover the oil pan to install the new gasket. This is what I order but I see in the thread fel-pro is not correct. Should I return if I can?
Old Feb 18, 2021 | 06:45 PM
zzcruzin's Avatar
Matthew, first off, what year are you working on? You can see in post number three, that those seals did not work on his pan. Post number 9 shows the right seals in the left of the photo. But like i said,what engine and year is yours?
Old Feb 18, 2021 | 06:46 PM
Matt - (Strong) suggestion - create a thread of your own and title it "Oil pan gasket replacement 1950 98" so you are not hijacking this thread which is to assist this OP with his 303 oil pan gasket install.
Old Feb 18, 2021 | 07:44 PM
maineolds's Avatar
great advice from vintage chief. It gets confusing when a new post builds on an old. Start that new post and I’ll be happy to help!
tommieb
Feb 19, 2021 01:22 PM
Oldssupreme
Jul 27, 2016 03:56 AM
Lady72nRob71
Apr 1, 2011 05:13 AM
dallasite21
Jul 21, 2010 04:05 PM
American Lead
May 31, 2007 05:02 AM
