1957 371 head questions 14 match 16?
Hello everyone,
I have some questions about my 57 olds with a 371. I dropped a valve on the right side head and I was wondering if a number 16 head would fit on the 371 which currently has a number 14 head.
I have found some on line just wondering. Thanks.
If anyone has a right side number 14 head they want to part with let men know also!
Thanks in advance
John H.
aka Hoat
Thanks in advance
John H.
aka Hoat
Hello everyone,
Thanks in advance
John H.aka Hoat
Thanks in advance
John H.aka Hoat
How did you drop a valve ?
How extensive is the damage to the head ? Do you have a pic ? Make sure you check the new head/heads for cracks.
Here is an NHRA spec for 1957 and 1958 heads. As you can see, there is a difference in combustion chamber volume in each year. They also used different thickness head gaskets.
