1955 Super 88 4dr Rear Drivers Door Not Opening
Hello, Everyone! I have taken on a 1955 Oldsmobile Super 88 Four-Door as my next preservation project. One of the hurdles is the rear drivers door. Both the exterior and interior door handles are not functional, but I need to get the door open to clean the carpets, remove the seats, etc. Am I able to get the door panel off while the door is closed or are there any other ways to get the door open? Any advice would be great!
Teagan (KS55Super88)
Here's some pictures from a 1955 Olds 98 4 door. I think it would be similar on your 88. Since I've got the window frame and door panel off I wanted to share what the door release linkage looks like. Let me know if these photos raise any questions or if you want to see any other views.
I just went out to see if you could put a slimjim or even a coat hanger down by the wing window to access the latch assembly. To see if you could just remove the metal frame without removing the door panel. Nope. There's metal covering the slot between the inner door and the support under the wing window. Here's some pictures of what I'm describing.
Howdy! Sorry it took ages to respond. One I got the door opened, I couldn't help but begin tearing out the interior to get it ready for reupholstery. I had to take off the upper window trim, then I was able to see the door lock mechanism one I pulled the door panel away enough. The lock mechanism was froze up, so a couple hits with a large punch and hammer later, the lock opened up and I was able to get the door opened. Thanks for the help!!
-Teagan
-Teagan
Switch Blade Betties
November 18th, 2013 07:39 PM
