1955 Olds 98, Bendix or Moraine Power Booster?
Old May 16, 2022 | 09:52 AM
sanemb6's Avatar
We have a bad Power Brake Booster on our 1955 Oldsmobile 98. Trying to figure out if it is a Bendix or a Moraine. We can't find a name on it. Any idea from the pictures, which it is. Thanks, Sandy
Old May 16, 2022 | 04:57 PM
Tedd Thompson's Avatar
You can distinguish the difference between the two by putting a magnet on the body of the power booster . The Bindex unit is aluminum body and will not be attracted to the magnet, the Muriane will stick.... Tedd
Last edited by Tedd Thompson; May 22, 2022 at 07:39 PM. Reason: I'm dumb and caint tell the differance between a booster and a master
Old May 16, 2022 | 05:44 PM
Charlie Jones's Avatar
Phantom Phixer
Judging by the part number cast into it, I'd say it is a Moraine cylinder.
Old May 18, 2022 | 02:20 PM
ignachuck's Avatar
Frank Ignachuck
Maybe I’m having a senior moment here but I thought the Bendix dipstick had a triangular shaped open ring on the top.
Old May 18, 2022 | 09:13 PM
griffey57's Avatar
Just get it rebuilt and you should be fine.
Old May 18, 2022 | 10:34 PM
Yes, but you should probably find out what it is before you try to rebuild it.
Old May 19, 2022 | 08:03 AM
Talking
Originally Posted by ignachuck
Maybe I’m having a senior moment here, but I thought the Bendix dipstick had a triangular shaped open ring on the top.
I don't think mine does, that is having a ring on the dipstick. Maybe we are sharing the same senior moment.... Tedd
Old May 19, 2022 | 09:26 AM
WHIPOLDS's Avatar
I have a Moraine unit in mine. I sent it out for a rebuild years ago. My original had a flat blade dipstick, when I got it back it had the triangle dipstick that was pit marked on the stick. Whenever I check the brake fluid, I worry that the triangle will break, I put anti seize on the threads. So apparently either type dipstick will work. I sure wish I had my original back.
Rick
Old May 21, 2022 | 05:07 AM
ignachuck's Avatar
Frank Ignachuck
Hmmm. I think I got it, Tedd. My '56 has factory AC. You can't access (or even see) the power steering dipstick from the engine compartment. Too much stuff in the way. You have to take off the front wheel and open an access panel in the rear of the wheel well. Then you can reach in and get the dip stick. It's a very tight area and the dipstick handle is very short. Maybe that's why it has a ring on it. I'm going to go with that answer anyway!
Now back to our original thread, already in progress.
Old May 21, 2022 | 06:40 PM
Gees, I'm glad I wasn't having another senior moment.... Tedd, But I am jealous of your AC.
Old May 22, 2022 | 10:15 AM
zzcruzin's Avatar
I have two Bendix units and they both have this dip stick. But mine are both 57's. If it means anything.
Old Jun 8, 2022 | 12:06 PM
Russ P in MD's Avatar
I found this old picture, which I think is a spare for the 55 S88. You can see the Bendix name cast in the aluminum portion as well, along with the triangular dipstick.
Old Jun 8, 2022 | 12:14 PM
ignachuck's Avatar
Frank Ignachuck
Woo hoo!! The triangular dipstick!!! Thanks guys, I feel much better now!
Old Jun 8, 2022 | 12:23 PM
griffey57's Avatar
55 thru 58 are interchangeable. I did it on my 58 olds years ago
Old Nov 24, 2022 | 07:48 AM
oldmercsrule's Avatar
Thanks, that is good to know...
NAS Backyard
Jun 15, 2018 11:48 AM
Mark's53
Aug 19, 2016 05:04 PM
Paaro
Tech Editor's Desk
Jul 30, 2015 06:16 AM
rkraft1952
Aug 19, 2014 08:34 PM
cobalt
Mar 2, 2014 03:10 PM
