1949 Olds 88 speedometer
Old Apr 10, 2021 | 05:46 PM
maineolds's Avatar
Hi friends. Can anyone tell me how accurate your 1949-1953 Olds speedometers seem to be? Mines off by 9mph. I’m adding miles quicker than I should be! At least I won’t get any speeding tickets!!
Ive thoroughly cleaned and lubed the cable but it’s had no affect. The needle rides smooth, no sign of binding internally. Stock size tires and gear set. Ideas?
Old Apr 10, 2021 | 07:21 PM
redoldsman's Avatar
Proud Viet Nam Veteran
My 54 registers about 8 mph faster than I am actually traveling.
Old Apr 10, 2021 | 08:19 PM
fredb_'s Avatar
My 55 Super 88 speedometer is about 6-7 mph fast with standard tire size.
Patolds's Avatar
Given that the tyre sizing and speedo drive gear are kosher...and that the cable drive only does what it is told to do...I would suspect some time in the past, a Diff centre swap?? highway cruizi' stuff. Take it up from 3:1 to 4:1 say and all the other stuff doesn't gel anymore.
This would mean less gearbox revs for a 60 mph run...and therefore a lower speed on the speedo indicated.
Just a thought.
Cheers Paddy.
Old Apr 10, 2021 | 10:52 PM
Ozzie's Avatar
You didn't say which transmission you have, nor if the error in the speedometer and the odometer are the same. If the two are the same you may be able to resolve it by changing the driven gear in the transmission.
Old Apr 11, 2021 | 03:06 AM
ignachuck's Avatar
Frank Ignachuck
My '56 speedometer is 5mph faster.
Old Apr 11, 2021 | 04:52 AM
maineolds's Avatar
Sounds like reading faster than actual is the norm for us. I have the only trans that was available in the 88 in 1949, the hydromatic. I am confident the drive train and gear set is all original. Nothings changed. Looks like “rocket powered” marketing got a little help in the form of an overly optimistic speedometer back in the day.
Old Apr 11, 2021 | 07:45 AM
Tedd Thompson's Avatar
Mine has been adjusted in the past but was done when I was running 60 series tires seems OK now that I'm running stockers... Got me curious I'll have to check it out.... Tedd
Old Apr 11, 2021 | 09:57 AM
maineolds's Avatar
Tedd, any recommendations on where to send the speedometer for calibration?
Old Apr 13, 2021 | 08:06 AM
Mine went in to Boardori in Chico and I believe they did the adjustment at the transmission not the speedometer... 530-891-4972 . You might give them a call it's been a while ago. Tedd
onofre442
Aug 30, 2017 08:56 AM
Jim Kniola
Nov 14, 2016 04:30 AM
piperman60
Aug 28, 2013 05:12 AM
R_CK_R
Jul 23, 2013 02:53 AM
markf14
Feb 24, 2012 11:14 AM
