1948 Turn Signal Issues - 6 volt
Old May 1st, 2023 | 05:12 AM
57J2Olds's Avatar
Hello,
For some reason I cannot figure out why my turn signals are not working.
When I activate the Signal lever the red light illuminates on the lever, however does not flash.
The bulbs also do not illuminate.
Any ideas?
Old May 1st, 2023 | 01:50 PM
Are all of the lamps good?
Old May 1st, 2023 | 01:57 PM
Have you checked the signal stat?
Old May 1st, 2023 | 08:06 PM
Tedd Thompson's Avatar
Is this an aftermarket part? Does it have an internal flasher or an under dash unit? Chase it backwards with a multi-miter and see where the juice stops...Tedd
Old May 2nd, 2023 | 04:05 AM
57J2Olds's Avatar
Hello,
As far as aftermarket, it looks REALLY old. Same interior color as the steering column. It has a flasher under the dash. I just ordered a new one yesterday so I'll try it out later today.
Please explain what you mean by "chase it backwards".
Old May 2nd, 2023 | 04:24 AM
57J2Olds's Avatar
Sorry, signal "stat"?
Also, if 1 bulb was bad would it cause all 4 not to flash?
Thanks!
Old May 2nd, 2023 | 11:57 AM
Find the last place you have a good 6 v and the first place you don't from that live wire. Somewhere between the two the juice is lost. Very well may be the flasher. One of the wires going to it should be hot on one side with the key on flasher engaged... Tedd
Old May 2nd, 2023 | 02:40 PM
Thanks!
Signal Stat is the relay that causes the lights to blink. 1 bad bulb would either cause the lights on that side not to blink or blink faster. Generally does not affect both sides. Can you post a picture of the unit on the column?
Old May 2nd, 2023 | 05:33 PM
57J2Olds's Avatar
Much appreciated help here.
I will post a pic tomorrow of the unit.
Thanks!!
Old May 4th, 2023 | 05:17 AM
57J2Olds's Avatar
Good morning,
So here’s the latest turn signal saga.
My new flasher arrived yesterday. I plugged it in and YAY! They are blinking now!
HOWEVER – All 4 are blinking at the same time!! Like I have hazards on.
So here are my questions:
1. I think I have 3 wires from signal lever to “somewhere under the dash”. I know at least one goes to my headlight switch; which I just replaced last week.
2. Where are the wires supposed to go?
3. The signals operate with key on….AND OFF. They must be connect to battery hot all the time.
4. I’m thinking I may have “the perfect storm” going on. I just replaced my headlight switch with an NOS one last week. Was my flasher bad as well and now I may have hooked up the wires to the new headlight switch incorrectly?
Any help would be great. Here’s a couple pics.
Old May 4th, 2023 | 09:34 AM
Post the wiring diagram of your new one.
Old May 4th, 2023 | 09:36 AM
57J2Olds's Avatar
This signal lever has been with the car for 60 plus years....I don't have a wiring diagram.
I wish I had one.
Old May 4th, 2023 | 09:56 AM
I misunderstood, I thought you got a new turnsignal switch and all. How many wires come out of the switch?
Old May 4th, 2023 | 10:07 AM
57J2Olds's Avatar
I'll need to count tonight after work.
Old May 5th, 2023 | 04:48 AM
57J2Olds's Avatar
Still trying to solve my 4 way flash issue.
I spent an hour under my dash last night with blood rushing to my head and feet touching dome lamp. I have the correct wires running from my signal lever to the running and tail lamps. Correct wires running from my lever to brake switch.
The only thing I see is that the previous owner has the signal power wire going to a “HOT all the time” lead on the headlight switch instead of the ignition. Key out you can operate signals.
Could this be the issue? I have not tried yet.
Could I have been given a faulty flasher?
Old May 6th, 2023 | 05:04 AM
maineolds's Avatar
Grounding issues are the cause for so many electrical gremlins. I'd encourage you to first figure out how that system is grounded, then test to be sure those grounds are working well. Is the signal unit grounded? Should it be? experiment with making new grounds to the light circuit and/or the signal device. Be absolutely sure the grounds are working. I use an ohm meeter to be sure.
Old May 7th, 2023 | 08:45 AM
57J2Olds's Avatar
Another issue I am seeing is that when I turn on my headlights........all flashers stop.
Old May 9th, 2023 | 05:43 PM
I don't think your car ever came with, a hazard feature, all 4 blinking at the same time makes me think you are getting feedback (short) from your hot side that is already in question. You might try divorcing the hot side and replacing that wire to a hot only with key on side of the ignition like the original had.. Another thought is that there could be a short in the turn signal itself, back feeding both sides of the switch bulbs, a bad ground as mentioned before could cause this....Tedd
asscutl
September 29th, 2022 09:56 PM
jkeegan
November 29th, 2017 12:10 PM
Borry
July 30th, 2014 06:51 AM
KZ442
December 7th, 2009 06:11 PM
allthumbs
January 8th, 2007 02:24 PM
Quick Reply: 1948 Turn Signal Issues - 6 volt
