1948 Trans question
Old Aug 30, 2021 | 07:39 AM
57J2Olds's Avatar
1948 Trans question
Hell again,
So I took delivery of her Saturday. My question is this:
When I pull the gear shifter to Reverse its a real bugger to get it in reverse. You need to kinda "play" with the lever to get it to "pop" into reverse and then you need to hold the lever or it will pop back in drive.
The guy I got it from told me it was a linkage issue.
Any idears?
Old Aug 30, 2021 | 08:01 AM
coldwar's Avatar
It's a linkage issue....assuming the motor mounts are not broken.
Old Aug 30, 2021 | 08:04 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I think coldwar is right on. I would check the motor supports before I screwed with the linkage.
Old Aug 30, 2021 | 08:16 AM
Tedd Thompson's Avatar
You might try the carb to transmission (long rod) first if as stated the motor mounts are solid. adjust a 1/8 turn at a time then try it with each adjustment. This adjustment sets the gear selector so that the transmission is not left trying to find the proper place to shift. It also to some extent adjust the duration between shifts....Tedd
Old Aug 30, 2021 | 09:57 AM
57J2Olds's Avatar
ok Thanks!
I'll dig into it after the heatwave is gone.
Reese Neis
Apr 8, 2021 07:18 PM
Jhucks03
Oct 6, 2020 10:02 AM
spaceman_spiff
Jul 2, 2017 03:35 PM
Bassemaa93
Nov 27, 2015 06:47 PM
Samson
Mar 31, 2009 06:13 PM
