'65 Cutlass auto floor shift conversion
Hello - new member with a '65 Cutlass automatic 2-speed column shift. I just got a correct '65 console to convert to floor shift, but no shifter or wiring. Can't find a '65 floor shifter. I've heard of the '78 and up floor shifter option, but what is the last year that can be used? I've seen some auto floor shifters for '80's Regals, Grand Nationals, & Cutlass, but wonder how far past '78 will work, or if there is an optimal year. Advice? Thanks!
Last edited by luap383; October 23rd, 2015 at 03:45 PM. Reason: incorrect information
Welcome to the site, I moved your post to transmission and driveline section. Post a proper intro with pictures in the Newbie section when you get a chance. As I'm not familiar with your console hopefully someone will get you the info you need shortly.
hvysupreme
February 18th, 2017 12:40 PM
67442nut
February 28th, 2013 01:54 PM
onofre442
June 25th, 2012 09:56 AM
