U-Joint Help
Old April 11th, 2014, 08:42 AM
C.W. Griswold
Daniel Marsh's Avatar
U-Joint Help
Hello all,
I am putting the engine trans and drive shaft in to the chassis tonight!! I have two questions, what part number u-joint (napa, koi, o'reilly) is used front and rear 1969 442 W30 and also what is the part number for the u-bolt kit to hold them at the rear. I think the u-bolt kit is dorman 81002 so I can order those but I need to know the u-joint number asap so as to get them before I leave work today..... Thanks in advance,
Kyle
Daniel Marsh is offline
Old April 11th, 2014, 09:08 AM
Octania's Avatar
Wouldn't the store have that information?
Octania is offline
Old April 11th, 2014, 09:16 AM
O'Reilly shows Lakewood Universal 23011 for both front and rear. Has a zirc fitting for grease. OEM U-joints didn't have that, so depends on whether that matters to you.
Advance Auto Parts shows both Lakewood and Driveworks (Part number DW-534G). Lots of choices, just use the website easy drill down to specify your vehicle. Both of the above u-joints are listed as exact fit replacements. The Lakewood one is categorized as 'performance' and costs more.
Moog - 534G, 234, 235
Brute Force - 2-3011BF
Neapco - 2-3010
Allan R is offline
Macadoo
April 19th, 2015 11:29 AM
1969cutlazz
July 28th, 2014 01:10 PM
nonhog
Drivetrain/Differentials
September 13th, 2011 08:58 PM
defiant1
October 29th, 2010 12:41 PM
Totumfrog
December 29th, 2007 08:51 PM
Quick Reply: U-Joint Help
