1955 324 & Hydramatic removal.
Old May 4, 2012 | 04:25 PM
Bikes&Rods's Avatar
Question 1955 324 & Hydramatic removal.
I just bought a 324 with hydramatic from a '55 Olds Holiday to put in a '36 Chevrolet Pickup I am building. I am trying to remove the transmission (which is good) to rebuild the motor. For some reason it moves about 1/4 inch and them stops. Pry bars and supporting the trans weight adequately don't seem to help. What could be causing this. I don't want to break anything but am very frustrated as everyone says it should come right out.
Thanks in advance for any help offered, Bill
Old May 4, 2012 | 05:30 PM
okie88's Avatar
The early Olds doesn't have a conventional torque converter. It has a 'coupler' that must be split. The front is like a flywheel. There are 32 bolts that hold it together. You will have to rotate the engine to get to all the bolts. Once they are all undone it will come apart. Remember to drain it first.
Old May 4, 2012 | 07:19 PM
Bikes&Rods's Avatar
Thanks for the response, but when tried that it still didn't come apart. The flange on the "not a torque converter" came up to the opening in the bell housing and everything stopped again. Could it just be dried grease/oil and dirt on the end of the splined shaft binding? If so any ideas how to clean , or how much prying force can I safely apply without damaging the coupler?
Old May 7, 2012 | 08:17 PM
Bikes&Rods's Avatar
Talking Ah, the missing link
So I got help from various sources and all failed to mention the critical component. You must first remove the bottom half of the bell-housing in order to remove the transmission. Mine was so covered in storage dirt and grime that I did not initially recognize the existence of a separate removable lower half of the cast in the block bell-housing.
With that removed and the torque coupler unbolted from the flex-plate there is room to pull the trans and torque coupler back and down separating the transmission from the motor. Now the trans is on a service cart and the motor is on an engine stand ready for further dismantling and assessment. Phewww! Glad to have that accomplished.
2blu442
Aug 22, 2015 06:30 AM
oldsmobum
Sep 8, 2012 01:20 AM
Mad Scallywag
18
Apr 20, 2012 09:06 PM
American Lead
24
Mar 17, 2009 07:48 AM
Jet Doc
Nov 2, 2008 11:55 AM
