Need to shift rearend over 1/2"
Old May 29, 2022 | 08:49 PM
romanss's Avatar
Hi All
I just bought a 1972 olds cutlass.
It has a 10 bolt rear with a pretty heavy duty sway bar.
I noticed the rear seems to be pushed over a bit.
I was wondering how do you adjust it back to center?
Thank you for your help.
Old May 29, 2022 | 08:51 PM
romanss's Avatar
Old May 29, 2022 | 09:43 PM
It's probably not the rear that's shifted over, it's the body.
Old May 29, 2022 | 09:44 PM
Before you begin considering a shift of 1/2” (or any length) is supposedly required, how did you determine this? Examine the lower control arms - they need to be of the “boxed” variety - not the open control arm variety. If you’re using the sway bar as a “gauge” from which you’re measuring distances, remove the sway bar completely and take new measurements. What are the conditions of the upper and lower control arms are they bent, show damage? If you are using the sway bar as a gauge to measure distance, as stated remove it and see if you come up with the same “seemingly” 1/2” disparity.
Old May 29, 2022 | 09:46 PM
As Eric suggested, as well. If you have no driving handling issues, 1/2” is almost negligible.
Old May 30, 2022 | 04:52 AM
romanss's Avatar
The more I read about this, the more I realized this is probably the case. The body mounts have been changed, so this does make sense.
I will have to put it up on stands and take a better (proper) look at this.
Thank you for taking the time and responding to my question.
Old May 30, 2022 | 04:55 AM
romanss's Avatar
I determined it, just by looking at the body how far it hangs past the wheel one side compared to the other. I now realize this was the wrong assumption. I will have to look at this a bit more thoroughly.
Old May 30, 2022 | 05:48 AM
Phoenix8990's Avatar
Nice looking car!
Steve
Old May 30, 2022 | 06:32 AM
1/2" of offset is well within factory assembly tolerances. The wheel wells are designed to provide clearance for worst-case mass production tolerance stackups with stock tire sizes. The problem comes when someone installs tires that are wider than stock.
Old May 30, 2022 | 06:47 AM
romanss's Avatar
Well, thats the exact reason why I started looking at it. Lol.
No problem. I'll just have to invest some time and get it straightened out.
Old May 30, 2022 | 06:51 AM
That was obvious from the photos.
Old May 30, 2022 | 08:41 AM
Once you establish that it is in fact the body, the fix is very easy. Just loosen all the body bushing bolts from the cowl back and shift the body back into the correct position. It can be done on jack stands, but much easier on a lift.
Old May 30, 2022 | 01:28 PM
romanss's Avatar
Since you guys are the experts....
Now that I have all the body mounts loose. What is the best technique to move the body?
Old May 30, 2022 | 01:34 PM
romanss's Avatar
I didn't mean that to sound smart ***. I have never done this. I figured id used a come along.
Old May 30, 2022 | 02:58 PM
A couple of pry bars, there are holes in the frame for this purpose.
Old May 30, 2022 | 08:42 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
This seems to be a common problem, my 70S is about 3/4" to the driver's side. As said, it is the body, not the rear itself. Be thankful the body mounts were recently changed, the bolts on mine are 52 years old. I have strong feeling some would snap off.
edzolz
Apr 16, 2021 04:49 PM
Mr Shifty Sidney
Suspension & Handling
May 6, 2019 08:54 PM
71OldscutlassS
57
Jan 26, 2019 06:37 PM
donfitzgerald
May 2, 2015 05:46 AM
willj
Jul 19, 2011 06:49 PM
