Will '67 Buick 225 V6 bolt up with '61 Rotohydramatic
Old Jun 26, 2017 | 02:03 PM
holidaysedan's Avatar
in a '62 Cutlass? Am told the standard '62 Cutlass 215 alum V8 was derived from the Buick 198 V6... so will a slightly later 225 bolt right up to the standard automatic used in '61/62/63? Would trans or carb linkage need changed as well?
Old Jun 26, 2017 | 04:11 PM
The 198 (and the aluminum 215) uses a bellhousing that looks like this:
The 225 uses the normal BOP bellhousing that looks like this:
Old Jun 27, 2017 | 08:08 AM
Thanks - so if replacing the original 225 alum v8 with a Buick v6 one must use the 198 early v6 version, not any of the later Buick v6s it appears?
So if one wanted to use a '67 Buick 225 V6s would a later THM that came with it bolt in with no or minimal mods?
Old Jun 27, 2017 | 09:57 AM
The Rotohydramatic 5 that came in the 61-63 Y-body cars is one of the smallest automatics built by GM. The only one that comes close is the TH200 (NOT the 200-4R), which is weak but probably adequate behind a 225 or 231. Anything else, like a TH350, will require floorpan mods. Of course, you'll need a custom driveshaft with any trans swap.
Old Jun 27, 2017 | 10:28 AM
thanks for that info!
Was the rhm-5 a true 3 spd or 2 speed like Powerglide, or fluid coupling like a DynaSlush? I looked in the brochure but it was vague, just ad-man speak.
FlatFenders
Aug 23, 2014 08:04 PM
Oldssupreme
Jan 17, 2013 10:32 AM
Oldssupreme
Jan 15, 2013 07:54 AM
Oldssupreme
Non-Olds Engines
Jan 13, 2013 05:59 PM
gmacolton
Apr 29, 2010 12:53 PM
