Will a 425 flywheel bolt to a 330
I doubt it. Unless the vehicle was manual shift they weren't drilled for pilot bearing/input shaft. I just went through my stash of 425 engines/crankshafts looking for a drilled 425 crankshaft, 11, none drilled. I found a drilled 455 crankshaft in a Marine engine, plus like new flywheel. The machine shop I use will machine the crankshaft for around $100.
