Trans identification
Old May 24, 2023 | 08:04 AM
DeWolfe's Avatar
Hey yall, this may be a dumb question but here it goes. I just recently bought a trans for my 69 cutlass project, I thought I was getting a th350 but this doesn't look like the th350's I have here. Hoping one of you experts can tell me what I got. There is no kickdown cable but it does have the vac. Modulator on the rear of trans. Also it has what looks like the electronic kick down like my th375 and my th400 have. The pan is different than my th350,th375 and th400. Also the original tag has been removed and replaced by a Wolfe transmission Inc. Tag. Any help is very much appreciated, thanks.
Old May 24, 2023 | 09:29 AM
That looks like an ST300 (Jetaway) pan, which is a 2 speed transmission.
Old May 24, 2023 | 10:13 AM
DeWolfe's Avatar
thank you very much for your comment, that would explain why I can only find p-r-n-2-1 when turning the shift lever by hand I assume. Were those a good transmission? Similar to a powerglide I assume?
Old May 24, 2023 | 02:17 PM
For a grocery getter they were good transmissions, for performance not so much. They have a very tall first gear, a T350 is a better choice. The only thing an ST300 has in common to a Powerglide is it's a 2sp, nothing interchanges.
Old May 24, 2023 | 02:32 PM
So I have to ask. How in the world did you get sold a two speed transmission for your car? Did someone tell you it was a turbo 350? Just curious.
Old May 24, 2023 | 05:05 PM
Other than having two speeds, it has nothing in common with a Powerglide.
Old May 25, 2023 | 06:10 AM
You should see if you can get your money back. I can't think of any circumstance in which a Jetaway would be a better choice than a TH350.
Old May 25, 2023 | 02:42 PM
Again...
Old May 25, 2023 | 06:14 PM
2blu442's Avatar
What part of the country/world are you in? I've got some extra transmissions including TH350's but I'm in the Pacific Northwest, Oregon. I would suspect others here do as well if you want to create a parts wanted thread. But please share your general location in case someone nearby has one they can reach out to you.
Wingshot
May 8, 2022 04:11 AM
justinj
Apr 28, 2018 03:35 PM
coppercutlass
Aug 4, 2013 07:21 PM
camron
Jan 6, 2013 06:38 PM
Insom
Feb 22, 2011 04:44 PM
