Ronnie
Old May 9, 2022 | 05:18 AM
66oldscutlass442's Avatar
Ronnie
Will somebody let me know if the Tremec T56 magnum transmission will fit in my 1966 Cutlass F-85?
I am replacing the original power train from bumper to bumper. I am replacing the original 330ci engine with a 350. In place of the original M-21 I would like to have the 6-speed Tremec.
I am thinking 9" Currie rearend with 3.73 gears.
Old May 9, 2022 | 08:24 AM
67OAI's Avatar
Old(s)GuysRule
Everything that I have looked at online states that the 6-speed will not fit in that chassis without tunnel modification. Some of the "kits" even come with sheet metal material for that purpose. There are versions of the 5-speed available which will fit without tunnel modification including the newer TKX model. That would be my choice.
Old May 9, 2022 | 12:31 PM
VC455's Avatar
Barely Registered
Jim is correct about the fit of the T56.
In the days before conversion kits, I put a T56 in my 1970 Cutlass (1970 probably had a bit bigger tunnel than yours). I had to remove the tunnel back through the floor pan brace to give enough room. The T56 is a TALL transmission.
Construction and completed shots below...
Gary
The hardest part, psychologically was cutting up that rust-free floor.
My stick position ended up 3" farther back than that on the factory 4-speeds.
815Cutlass1972
Jan 19, 2022 04:00 PM
Bernhard
May 22, 2020 06:48 AM
goldie442
Aug 21, 2015 10:41 AM
firefighter5174
Jun 2, 2013 07:47 AM
