Dearborn three speed value
Old April 1st, 2013, 06:49 PM
ihengineer76's Avatar
Hi everybody. My dad recently purchased a Pontiac 400 as a spare for his GTO and it came with a Dearborn 3 speed and the accompanying bell housing. He was curious what these are worth and so I said I would pick the brains of my fine fellow Olds enthusiasts. The tranny is in pretty good shape internally with no chipped teeth or wore out syncros. It is actually a pretty tight trans and shifts in and out of all the gears smoothly. It also has the shift linkages. I have heard that these were a pretty stout trans. If I remember right, the case is a '68 casting and the tail housing is a '65 casting. Thanks in advance guys!
ihengineer76 is offline
Old April 1st, 2013, 07:01 PM
Oldsmaniac's Avatar
I dont know what they are worth but I tried to sell the one I had for a hundred and there were no takers. I dont think there is a demand for these at all...
Oldsmaniac is offline
Old April 1st, 2013, 07:12 PM
66400's Avatar
The BOP bell housing will command 150 easy, the toploader while a stout tranny does not have any following at all. I've watched several on ebay that never got a single bid. Henry
66400 is offline
Old June 28th, 2017, 04:46 AM
67firebird's Avatar
If you still have this transmission I am interested.
thanks
Jeff
67firebird is offline
Old June 28th, 2017, 06:57 AM
Oldsmaniac's Avatar
http://www.ebay.com/itm/1968-Dearbor...xYMMVA&vxp=mtr
Old June 29th, 2017, 08:10 AM
67firebird's Avatar
Thanks,
I saw this but because its missing shifter and linkages i was going to keep looking.
I appreciate it!
JpMotorsports
April 7th, 2015 06:36 AM
Oldsmaniac
June 23rd, 2014 06:32 AM
lunaboy
September 12th, 2013 06:43 PM
70worm
August 29th, 2013 02:48 PM
bobfo1
July 22nd, 2011 11:22 AM
Quick Reply: Dearborn three speed value
