4spd auto or 5 manual??
Ok I need to get my 70 cutlass a better trans, a turbo 400 is stout, but my wallet for gas is not. (I plan on driving 75-80mph 100miles round trip on weekends)
What would be cheaper/best way to go, a 4spd auto that can live behind a 455 with about 500 lb of torque, or a 5 speed tremec?
If I were to get the 200r-4, or a 700, I would want to replace my console shifter to a dual gate, with the provision for the 4spd setup.
If I went the manual way (fun way!) I would need to set up the crank to accept the throw out, and possilby modify the tunnel area. That and modify my console to accept the manual, be it a rubber boot, etc.
I already have a bellhousing for a manual, and the clutch petals to add to my 70, but would need linkage or I am going to guess go hyd setup.
So any suggestions/ideas? I think I saw on ebay some stores selling a complete t-500 setup for under $3,000. Im sure if I went with a 700 it would be more then that (mind you the shifter).
4l80E??!! Thats a huge ! lol I think I would shy away from the e, and maybe just get the 700r4. Same trans but no electric to worry about.
But then again in the future when I run an EFI system, adding in the E would be a breeze
What do you mean console adaptors?? I would get rid of the shifter now and put in a dual gate, or some rods!!!
I have installed many TH700R4 transmissions in performance cars and trucks and have one behind a built up Big Block Chevy in my very heavy 77 ElCamino now. I have run the dog out of it for 18 years with no problems. They
can be easily built to hold up to a Big Block, and will fit in your car with the least amount of modifications, no tunnel or console changes and you could then add the dual gate shifter.
ps: I own an automotive and transmission shop and would be glad to help you with your change over if you need any advice. Charles
4 speed auto
I would run with a 4l65 instead of a 4l80. The 4l80 will rob you of more HP. I would say you could go with the 700r4 if you want to deal with the TV cable, it is not fun. If you go with a 4l65 or 70 I believe they have 5 planets instead of 4. I used to rebuild all of these tranny's for racing. I owned BP performance and that is all we did. Just get the controller so you can run it with an older carbureted engine. Good luck
I guess it really depends on what you are using it for. My brother seems to think with the right close ratio 4 speed a guy could out shift a automatic, I strongly disagree. It has been my experience that a built automatic will get the job done in the 1/4 mile much faster than a manual. Now as far as manual transmissions go I think they are a lot more fun to drive. I would love to own a 78 Cutlass with a factory manual transmission. There is also the fact that you do not have to run a stall converter with a manual trans, so I guess it really depends on the application.
I'm a 4 speed guy through and through. BUT, as bad as I miss them, I run automatics. They are dime a dozen, cheap to build and can still be a bit fun with the right shift kits, tweaks and a nice ratchet shifter.
As far as your question, the Tremec 5 speed has a chance in hell to hold up, the 700r4 Does Not. You can do some mods to the 700r4 and make it take a little more abuse but nonetheless, don't expect years and years of service out of it.
I'll agree with the 4L80-E suggestion if you're deadset on an OD trans. Can you get around the E? Yes you can. I'd say you obviously won't mind if you're willing to work a 5 speed and a clutch. The trick to running a 4L80-E without the E, is to run a full manual valve body and shift it yourself. No electronics needed then.
You need a lot of parts to convert that car to a manual. It was worth it to me. I am planning on a Tremec in the winter. The builder is 6 weeks out at this time and it is Hot Rod season here in Chi Town. Gotta drive em when you can. I have a friend w/ a 700R4 from Bowtie Overdrives that so far has been fine. Crossed fingers and all. It would be MUCH easier to stay with the auto than convert to a manual. Just my 2 cents.
I guess that what I'm trying to say is if your looking for better gas mileage any standard trans is going to set you back a minimum of $2500 (and that's for your basic Muncie that isn't going to give you better gas mileage). I don't know what a good auto tranny with an overdrive costs but probably less than that. Either way it's a lot of years of driving your TH400 the way it is.
So you're looking for better fuel economy for 5200 miles a year. At 14 MPG that's 371 gallons. If you get 20 MPG that's 260 gallons. The difference is 111 gallons or about $389. That's if you drive 5200 miles a year.
ignachuck
June 12th, 2015 05:29 PM
TWP442
May 24th, 2013 06:37 PM
