1968 Delta 88 Posi Upgrade
Old May 20, 2024 | 06:18 PM
VisbleBoatmobile's Avatar
As Seen on Roadkill
Looking to swap out my 2.56 open to a posi unit. What rear end type is in this car? It’s a “12 bolt” but I’m wondering if it is an O type with the 8.5 ring gear or if it is a regular 12 bolt.
Old May 21, 2024 | 05:46 PM
cfair's Avatar
You’re on the right track to put the 2.56 away. It gets great mileage, but no one is keeping these cars for mileage these days. You very likely have type O or maybe other exotic (type P) rear end, it is very unlikely to be “regular” anything. Don’t even ask about swapping in anything Chevy. Just plain different.
Your safest swap is a complete donor rear end from another big Olds from 1965 to 1970. The idea there is to get a complete replacement and use the best of both to build something safe & reliable. If you’re in the Midwest, check out French Lake Auto parts in MN. They have more than a few big Olds from the mid-60s.
You might get really lucky and find an Olds “Anti-Spin” (aka posi) unit, but these were rare in the day. They also degrade with use and I don’t believe they’re rebuildable. I’ll be happy to be corrected if I’m wrong. I’m not a differential specialist. Just a hobbyist.
It took me many, many years to find 3.23’s for my big Oldsmobiles. And both of mine are open (aka not anti-spin/posi) rear ends. I believe the most common big Olds rear ratios were 3.08:1. If you chase performance models as donors (Starfires/ Police specials) you may find 3.23’s as well. Either of these will be a big performance improvement over 2.56:1.
My point here is, if you come across a 3.08 open rear end, that may be enough performance improvement to keep you happy for a time, perhaps a long time, until you find the ratio you’re looking for. Out at the performance edge Olds probably built a few big cars with 3.42’s, but I’ve never seen one.
When you get to redoing the rear end, keep your axles and if you’re swapping in different gears, that’s a good time to do rear bearings as well. And rear brakes for that matter.
If you want to go high buck exotic, I have the impression that Ford 9” custom with custom axles might be the ultimate, but pricing that would be something like a mortgage payment.
Cheers
Chris
Old May 22, 2024 | 07:07 AM
Your car uses the big car Type O axle, which has a 12 bolt cover and a 9.375" ring gear held to the carrier with 12 bolts. Aftermarket parts for these do not exist. Factory posi units with descent ratios are unicorns. Impala axles do not fit. Unless you can find a factory unit (and if you do, buy a lottery ticket), an aftermarket Ford 9" is about your only option.
OldsmobileEric
Oct 14, 2020 05:49 AM
oldsw30
Nov 26, 2019 04:27 AM
servexcell
Nov 20, 2015 07:43 PM
scooter123
Drivetrain/Differentials
Mar 25, 2013 07:25 AM
oldsf85455
Mar 16, 2011 05:02 AM
