When my car shifts second the tire chirps
Seriously? You're asking without providing ANY information other than a TH-400. Size of rear-end, open vs posi, size of engine, RPM when shifting, WOT, radial vs bias-ply, type of car. What you are asking is nearly impossible to answer without appropriate information.
68 455 C heads
open rear SA code
Not sure what year trans maybe orig.
have to check code
I was kinda trying to be funny, most turbo 400 chirp second when you lean in it alittle but this one just driving slight on the accelerator it gets about 1 foot chirp
225/70/14 BFG
open rear SA code
have to check code
225/70/14 BFG
Some of the factory performance TH400 had a pretty aggressive valve body calibration. Even those had to be mild enough that part throttle shifts wouldn’t scratch the tires on every shift. It sounds like someone installed a shift kit.
Are you wanting to tame the shifts?
