what is the location of vaccum modulator valve?
This morning I bought a vaccum modulator valve because I was told that that may be the cause of a little white smoke coming out of the carburator area. Plus the transmission won't shift into second gear or work in reverse. My question is:
Where on the engine is the modulator located? I have an '84 Delta 88 with a 307. Thanks
If you have the stock tranny in this car, then it is most likely the TH200.
The modulators should be on the tranny itself.
The white smoke around the carb area is more likely from another cause, like oil leaking from VC gaskets burning on the exhaust manifolds.
I'm not sure which transmission I have. The clerk at the parts store gave me the valve when I told her which car and engine I had. I looked up under the trunk lid for the service parts list, but there weren't any numbers/letters that looked like the one mentioned above.
Let's start with the easy question - is it a three speed or four speed?
I think it is a three speed. I looked up an old post and found a transmission shop mechanic told me it was a T350. edit: I searched Yahoo using "Image" and found a TH350 Transmission with a picture. On the passenger side near the rear I saw what looked like the part I bought so I went out and jacked the car up and looked. It looks like the modulator. But then again I saw a picture on the web that captioned a (looks like) a "transbrake solenoid." ???
![Cool](https://classicoldsmobile.com/forums/images/smilies/cool.gif)
I found directions on a DIY site that tells how to change the modual in a Ford Truck. It says the vacuum modual is on the passangers side of the transmission in the back. It said to loosen the bracket holding the modual in and take the old one out being careful not to drop the pin and then putting the new one back in its place.
Does this sound about right? I think the modual on my 88 is about the same.
![Unhappy](https://classicoldsmobile.com/forums/images/icons/icon9.gif)
The part you bought is the modulator. The "pin" being referenced is the modulator valve, which is operated by the modulator. Neither item is going to fix your transmission if it won't go in reverse. It needs to come out for an overhaul. Sorry.![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
DW
DW
jonesolds442
December 3rd, 2013 05:00 PM
