What a Dipstick (transmission)?
Would this be a good idea? Put an additional "O" ring at the top below the ridge? Or do you think the dipstick tube wouldn't seat all the way in the transmission? I have one of the "high quality" O ring assortments from Harbor Freight....the o ring that fits the groove seems too skinny. Are all o rings the same thickness? depending on their diameter of course.
Seems like I need a thicker one of that diameter. And yes, it was puking ATF all over my garage floor.
What fun removing that bell housing bolt that the dipstick mounts on.
You need a slightly thicker O ring on the groove. That top O ring will not do much. If you must do something at the top, a daubed on wipe of RTV might work, but make very sure none of it gets into the trans and use very, very little.
dantecl
October 27th, 2013 02:50 PM
steel
November 8th, 2012 08:28 PM
