what is a 64-65 muncie worth???
I bought a transmission at a garage sale-believe it or not... I saw it sitting on the floor in the pole barn. I asked the owner what it was and he said it was a 5 speed. I thought it looked like a older GM 4 speed so I said " are you sure its not a 4 speed?" He said " well maybe it is a 4speed" well anyway from what I can tell its a Muncie m 20 64 or 65. # on case is 3851325. Any idea what I should try to sell this for? Thanks Greg.
If it has a 1325 main case,its a 64/65 Muncie trans. It appears to have the drivers side speedo which is also correct for the 64-65 trans. The early trans have a 7/8 cluster pin where as the 66 up Muncie trans had a 1" cluster pin.
Supradean
March 15th, 2014 06:21 PM
